Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-17-2012, 02:19 PM
chamblizi's Avatar
chamblizi chamblizi is offline
1975 Ford Ranchero
chamblizi is starting off with a positive reputation.
FINDING TDC?
Hey how do i find top dead center i am changing my timing chain soon.
(SOLVED)
__________________
"I'll learn my self, where is my beer!"
  #2 (permalink)
Old 06-18-2012, 06:14 PM
Beechkid Beechkid is offline
Garage is empty, add now
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
Ok, pull the valve cover & #1 spark plug.
place the tip of a finger in the spark plug hole to feel pressure or suction (if you are working by yourself, you can rig up a baloon to part of an old spark plug that screws into the hole too)
rotate crankshaft (with wrench) until you feel pressure stop & it starts to suck, look at valves, both exhaust & intake should be closed.
reverse rotate the crankshaft until it starts to suck again....when you feel the point that it does not suck or push air out, the piston is at top dead center, this will also allow you to verify if the timing marks on the crankshaft are correct/true.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #3 (permalink)
Old 06-25-2012, 01:01 PM
Jippah's Avatar
Jippah Jippah is offline
1967 Ford E-Series Van
Jippah is starting off with a positive reputation.
That is a very unique way of finding TDC.
I've always done it the hard way and removed the cylinder head to do a visual check :\
But that was on little SOHC 4 bangers
  #4 (permalink)
Old 07-04-2012, 08:47 PM
twosfamily twosfamily is offline
twosfamily is starting off with a positive reputation.
I like that balloon trick! I will have to try it sometime!
Tags
1, 2003, 289, 292, 42, f150, find, ford, lightning, navigator, taurus, tdc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
