What was in my diesel
#31
No WIF light. Drain every month or two. Only has 18K since purchase November of 10. I'll install the new filters tonight that have been in the truck for several months, also I got some PM22 to add also.
I did do a second drain yesterday after making the block and had a very small amount of water without the "gold" color this time.
Got to get her ready for about twelve hours of RV towing starting Thursday.
#32
#33
There's no good way to tell where or how this water got into the system, but there's a good chance that this is simply the fuel/water separator doing it's job. Remember that this is exactly what's supposed to happen if there's a small amount of water in the fuel. The water will settle out in the DFCM and get drained out, just like happened here.
While I would be a bit nervous in your shoes this isn't necessarily a catastrophic thing.
#34
Keep in mind he said previously he runs Bio-diesel sometimes and water doesn't fall out of bio like it does #2 diesel. Some of the water will stay suspended in the Bio-diesel and go right to the HPFP and injectors. That's the biggest problem with Bio-diesel, not being able to efficiently separate out the water in the fuel.
Just my .02
With that much water in the separator and some Bio-fuel in the tank, it's safe to say there has been water ran through the HPFP. Not saying that it's doomed or anything of the sort, just that there's not a good chance of any fuel system problems being covered under warranty. Almost guaranteed there's rust (to some degree) in the fuel system now and that seems to be a guaranteed 'no warranty' based on previous threads with similar problems.
#36
#37
Regarding the water separation in Bio-diesel this has got to be somewhat worrisome for folks who can't get or hard to find #2 diesel like in Utah. But since Ford slaps the bio badge on these new 6.7's I guess you just have to drain/replace filters more often . Since learning of the HPFP debacle I'm very conscientious on where I fuel up.
__________________
2012 F350 6.7L 4x4 Lariat Ultimate FX4, Chrome package, KR, Nav, SRW, CC, LB, 11.5K GVWR, 3.55 ELA
Traded: 2006 F350 6.0L 4x4 Lariat, SRW CC LB
__________________
#38
I still think I would drop the tank like I said earlier.
#39
My fuel/water separator gets drained nearly every tank. On my recent 2k+ mile round trip I drained at home and my destination. That equated to a tank and a half between drains.
I will say that on my way home I filled up in the rain and had water getting in to the fuel opening (downpour and I had the rain on the roof blowing over to the side dribbling right over top the spout). There wasn't a whole lot I could do and it was 10:00 and 14 hours in to my trip, I just wanted to get home and wasn't going to wait for hours for the rain to pass so I could fill up dry. That having been said, my separator will be getting drained a few times this tank.
#40
#42
As to the amount of water tripping the WIF indicator on the OP's truck...not nearly enough. It takes just under 8 ounces of water to light the light. He would need a bunch more than he has shown us.
Everyone needs to keep in mind that there does not need to be internal rust in the HPFP to get a warranty denial. My truck had no rust in any area that fuel flows. All Ford needs is a mating surface where the sensor meets the pump to be discolored and bye bye warranty. This area sees no fuel flow. BTDT
Regards
#44
Not sure I understand what Utah has to do with that. I have a hard time finding anything but #2 diesel. It is rare to find any biodiesel around here. We are not the corn belt. Any bio has to be shipped in. Utah has a bunch of refineries and our crude oil is high in Parafins waxs.
#45
I have all the parts from my HPFP repair. Included in this pile of Ford junk is the OE water separator. I filled the separator using a graduated cylinder until the water reached the switch. It took 7.8 ounces to fill the bowl to the switch...
just reporting what I measured...
Regards
