clutch question - Ford Truck Enthusiasts Forums
clutch question
Old 06-17-2012, 12:38 PM
bad a$$ roth bad a$$ roth is offline
bad a$$ roth is starting off with a positive reputation.
clutch question
hi all, my clutch finally went out and im doin my first clutch job ever, i am a mechanic just never had the opertunity to do a clutch, and after some very carreful decision making im using hd f250 over 8500gvw clutch and flywheel. originally i was under the impression from the characteristics of the lugging motion when letting the clutch out thati had a dual mass flywheel, after disassembling i find that i do indeed have a smf but it was my actual clutch plate that was creating the dual mass sensation. im not too concerned about my ride im more for durability and when u ull somethinout with a dual mass flywheel once it starts slippin thats all it does, im curious if any of uns know if the early 80s trucks will have the springless clutch material oreven later model 80 into the ninties? any help woud be greatful. its an 87 f150 300 I6 np435/205. I use trucks mostly as high speed tractors. i hual roughly 1500 to 1800 lbs daily in tools.
Old 06-17-2012, 04:39 PM
did some quick light research and believe im lookin for an undampened clutch disc
Dual mass or single mass flywheel andrew78 1994.5 - 1997 7.3L Power Stroke Diesel 3 07-30-2015 03:54 PM
clutch options abowman 1999 - 2003 7.3L Power Stroke Diesel 5 12-24-2014 06:53 PM
DMFW to SMFW Question Wt91 1994.5 - 1997 7.3L Power Stroke Diesel 2 11-10-2014 12:59 AM
1995 F250 Flywheel problems 70Post455 1994.5 - 1997 7.3L Power Stroke Diesel 6 01-15-2009 08:48 PM
Dual Mass flywheel problems on 1992 F250 04hdchick Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 01-15-2006 09:23 AM
Tags
20, biography, buying, cars, mexico, news, oklahoma, powered, smf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
