92 f250 ball joints
Old 06-17-2012, 06:27 PM
norfolknova's Avatar
norfolknova
norfolknova is offline
92 f250 ball joints
Hello everyone,
I recently picked up a 92 F250 4x4. It has a Dana 50 front axle with 4.10 gears and a 3920# front axle weight. It is in need of upper and lower ball joints. The problem I am having is every parts sight I have been to lists either 3850# exc.4.10 gears or 4600# front axle weights. None of the local parts houses stock any of the ball joints so I can't just take the old ones off and take them with me to match them up. I also do not have a garage so I don't want to order a set, just to get it apart and have them be the wrong ones then have to leave the truck sitting on jack stands in the drive way for a few days while the other set is ordered.
So does any one know for sure which ball joints would be correct for my axle?
Thanks in advance
Matt
Old 06-17-2012, 07:14 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Go to tireclub.com
Order the XRF ball joint set for 129 shipped to your door. The TTB dana 50 and D60 BOTH have the same ball joint no matter what the axle weight rating is
abranz
12-26-2016 12:51 AM
cochran07
01-01-2010 04:13 PM
hucka1a
10-26-2008 09:43 PM
gene17847
07-29-2008 10:28 PM
Quick Reply: 92 f250 ball joints
