86 f-250 rear drums
If you replace the axle, replace the backing plate too. Ask me how I know that! hahahahaha
The brake shoes won't allow the drum back on, because it got bent too.
Then you have to pull the axle back out... again.
Been there, Done that, Unfortunately , more than once, because I'm old and a slow learner
I aint exactly sure about the smaller axles, but I work mostly on bigger rigs running the full floating axle. I have seen axles snapped in half, but never seen a full floating axle cause the wheel to vibrate, or wobble.
I am more prone to go with bearings. Easy way to find out is to put the tire back on and wiggle the tire so to say while its off the ground. You may have to put a lot of umph into it, but Its a place to start.
mauicruza
11-11-2008 06:57 AM
Nitramjr
07-19-2008 08:27 AM
bmiller44685
1983 - 2012 Ranger & B-Series
07-12-2008 09:05 PM
FutureFordOwner8
12-27-2006 09:30 PM
TK139
05-12-2004 07:13 PM
