carb 302 and manual 5 speed swap - Ford Truck Enthusiasts Forums
Old 06-17-2012, 10:10 AM
BIGskinny BIGskinny is offline
BIGskinny is starting off with a positive reputation.
my buddy just got a 91 lariat carb 302 manual 5 speed. the speedo isnt hooked up an neither is the tack. is it possible to hook the tack thats in the dash cluster up? also this truck was orginally a auto so can you hook the speedo up? or does it need a different cable? thanks in advance
Old 06-17-2012, 11:32 PM
fordrulez fordrulez is offline
fordrulez is starting off with a positive reputation.
needs a new cable for speedo to work as for the tack its wiring is been changed I would buy a new one from parts store
Old 06-18-2012, 01:59 PM
thats what i was thinking. i figured he would need a new speedo cable but wasnt positive on the tach part. thanks for the input.
5.0L idle rpm raven3 2015+ F150 4 02-03-2015 09:33 AM
speed sensor, how do they work? Greg5OH 1999 to 2016 Super Duty 10 07-13-2014 04:20 PM
rpm gauge installation 1985 f150 4 speed manual mattthegreat 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 03-06-2010 10:46 AM
troubles finding transfer case tail shaft hellmjama 1987 - 1996 F150 & Larger F-Series Trucks 0 11-05-2006 09:31 PM
cruise control doesn't work 84_F250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 07-31-2002 09:09 PM
Tags
302, 91, conversion, early, econoline, f150, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
