Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 06-17-2012, 08:41 AM
jwhitetail jwhitetail is offline
Garage is empty, add now
jwhitetail is gaining momentum as a positive member of FTE.
Question Power windows
03 CC got in the other day, fired her up, windows and radio not working, shut her off, started it back up and fine, it did it again yesterday, there is a 30A ciricuit breaker fuse, for the windows should i replace it? Or is there something else to look for. thanks in advance.
  #2 (permalink)
Old 06-17-2012, 11:52 AM
woodnthings's Avatar
woodnthings woodnthings is offline
2002 Ford F-350
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Sounds like your Vehicle Security Module (VSM) is the cause. It is located behind the radio up in the dash area. If you replace it, you will need to have it programmed by a dealer. A used one out of a '02-'03 CC and it should work.
__________________
Ken
2002 F-350 CCLB 4X4 Website, HD4R100 , T-500, Melling LPOP, Gen-2 FRx, Bellowed Up-Pipes, Riffraff OCR, , Braided Brake Lines, CAC Boots & Billet Plenums, Aeroforce Scangauge, 4" Diamond Eye, Powerslots, Ported Compressor Housing, DP Tuner-F6, AE, KCM S.S. HPX, S&B Filters intake, Quad pod w/ISSPRO EV2's, Big Head , 6.0L Trans Cooler,
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
