Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-17-2012, 07:53 AM
Southfork894x4's Avatar
Southfork894x4 Southfork894x4 is offline
1989 Ford F-150
Southfork894x4 is starting off with a positive reputation.
Jimmy Byers
89 4x4, 4.9 inline 6 dies when the AC is turned on
Just bought my first ford 4x4, truck runs great until you turn on the AC. Motor will stumble with RPM's going up and down until it just quits running. Turn off the AC and it cranks right back up and runs fine. The idle control valve has been replaced or at least the guy said it had been when I bought the truck. Just not sure how to start trouble shooting this issue. Any help would be a big plus. Thanks Guys
  #2 (permalink)
Old 06-17-2012, 08:09 AM
Eddiec1564 Eddiec1564 is offline
Garage is empty, add now
Eddiec1564 is gaining momentum as a positive member of FTE.Eddiec1564 is gaining momentum as a positive member of FTE.
What happens if you throttle it up? Does it still lug the engine down or runs? Also does the AC work when driving down the road? Could be a AC compressor locking up or the ECU is not seeing the AC on command to idle up the engine (pin 10 on ECU goes to AC clutch).
My 89 F250 does the same as I have a bad connection from the AC clutch to the ECU pin 10. It will surge the idle at start up and sometimes stall if I have the AC on.
__________________
95 E350 460/E4od 4.10 The Bus
89 F250 2x4 302/AOD 3.55
84 F250 4x4 300/np435 3.55 The BLUE MULE
85 Plymouth Caravelle
73 Buick LeSabre
  #3 (permalink)
Old 06-17-2012, 08:18 AM
1989 Ford F-150
Jimmy Byers
If I give it gas it runs fine but as soon as it idles down the engine dies. I will check the connector as well and see if the AC clutch is kicking in.
  #4 (permalink)
Old 06-17-2012, 08:54 AM
If the AC is working while driving down the road. I recheck the idle air valve. The passage ways could be plugged up going to it even with a new one.
__________________
73 Buick LeSabre
  #5 (permalink)
Old 06-22-2012, 09:45 AM
1989 Ford F-150
Jimmy Byers
Checked the ICV and did not see and plugged port holes, cleaned it out anyway and then back on the truck. Same issue as before but I have noticed that at times the idle will drop way down and act like it is going to die and then rev back up. Does this a couple times and then idles right for awhile. Most time it does this when down shifting to stop or turn. It also will shut off sometimes as well. TPS, ICV, Air leak not sure which way to go.
Tags
1986, compressor, engine, f150, ford, kicks, stalls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
