Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #16 (permalink)
Old 06-18-2012, 07:44 AM
Spktyr Spktyr is offline
1995 Ford F-350
Spktyr is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 427 fordman View Post
Browser? remember I'm not computer friendly. Is that windows vista? Last version of adobe was just installed.
Vista is your operating system. Do you use Internet Explorer to view this site?
Try right clicking on the link to the TSB and telling it to 'Save this link' - that will produce a file on your computer that you can open with Adobe Reader.
  #17 (permalink)
Old 06-18-2012, 07:57 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
Garage is empty, add now
427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.427 fordman has a very good reputation on FTE.
Ya, internet explorer. I'll go try that now.
__________________
Darin I BLEED BLUE 76F250 66 fairlane dragcar514
1997 F250 HD 7.3,3.55-4.10 swap done,156k,140VIDM,HPX, 3-4"tymar w 4"straight pipe,ccv mod, S366 turbo, DIY 6637, elec. fuel,rosewood stage ones,php tunes,T500 HPOP,180 tstat,6.0 fan,6.0IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and triple disc billet converter, upgraded trans, F550 leaf springs,mean green alternator and starter,SD dual tensioner upgrade, cold ac mod
  #18 (permalink)
Old 06-18-2012, 08:28 AM
I don't know what the hell I'm doing. I right clicked it and it "saved target as" and it said it was saved to adobe, but I can't find it. Tried to save it again and it said it was already saved. I'm so bad with these damn computers, sometimes I want to throw this thing through the wall.....
I gotta go do something for a bit and get off this damn thing before I do.
__________________
  #19 (permalink)
Old 06-18-2012, 08:37 AM
fordpride's Avatar
fordpride fordpride is offline
Never done with mods
1997 Ford F-250
fordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to behold
this is the best I can do for now Darin. I'm on a IPhone
Cut out the grey areas
Click the image to open in full size.
__________________
Mike. 97 F250 totaled 11/19/12 B.E.S.T. map Louisiana FTE Member Map
2012 Ram CC 1500 5.7 Hemi
Diablo sport trinity hemi fever tune, 87mm throttle body, BBK headers, HF cat, 14" magnaflow, AFE intake, 180* T-stat. All waiting for time to be put on.
When married you have two simple choices. You can be "Happy" or you can be "Rite" you can't have both
  #20 (permalink)
Old 06-18-2012, 09:02 AM
1995 Ford F-350
You need to tell it to save to your Documents folder or your desktop, not to 'Adobe'.
  #21 (permalink)
Old 06-18-2012, 09:06 AM
1995 Ford F-350
Also, see this for how to save a file to your desktop:
http://solutionfile.trendmicro.com/s...desktopv7.html
Further, I would suggest these reading materials:
http://www.amazon.com/gp/product/078...ce-full-site=1
http://www.amazon.com/Complete-Idiot...pd_sim_sbs_b_3
Despite the titles, they're actually pretty good and not condescending.
  #22 (permalink)
Old 06-18-2012, 09:33 AM
Before looking the complete idiot one should fit me good. I'll check them links out.
Thanks Mike. I googled it and came up with some other help, but I'm still not 100% sure how much to cut. The other photos I found said to cut that first pic flush with the bracket and the other little brace on it cut 1/2 inch lower. Is that right? That the only cuts I have to make?
Thanks again
__________________
  #23 (permalink)
Old 06-18-2012, 09:58 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.
Try this link, maybe it will work for you. The cuts just make everything flush.
Edit: What you discribed about the cuts is correct.
__________________
Glenn
The Mule-96 2WD F250 EC/LB auto, Lots of Mods!! Semi retired, still runs great after years of pulling!!
The Mare 97 dually cc, T4 & s366 turbo, stage II's, IC, studs, springs, pushrods, John Woods auto, 4:10 LS, efuel, FS2500, HVHF IDM, IH water pump with filter, 6.0 trans cooler, 6.0 fan, MBRP 4", SD dual tensioner, 6637, 220 amp alternator, powermaster starter
  #24 (permalink)
Old 06-18-2012, 10:08 AM
Thanks Glenn, but that link doesn't work for me either. As long as what I said is right, I'm good to go.
__________________
  #25 (permalink)
Old 06-18-2012, 10:58 AM
Here we go again, I've got another question. My new kirby double pulley for the alternator seems to be a little smaller in diameter than the stock one (needed for the york). I read spktyr's thread on belts, but really don't know what to get. I was going to order two from partsguyed, but question doing that now. I remember cutts mentioning this about the pulley somewhere but can't find it. I pm'd him once quite a while ago but haven't seen him around for a few months. I don't know if he has the dual tensioner though..
I'm starting to get frustrated and a little angry at this point..
__________________
  #26 (permalink)
Old 06-18-2012, 11:02 AM
Ya, cutting the bracket is a little nerve racking because you then can't go back to the stock tensioner but after you do it you realize it was no big deal. Cut the bolt hole flush, then chip away at the flange until it will clear the dual tensioner and your good to go. I don't know if the link to the thread where the guy used a sawzal was posted but it worked good. Cut the flange every quarter inch or so and chip it off. Good Luck!
Edit: Can't help you on that one.
__________________
Glenn
  #27 (permalink)
Old 06-18-2012, 03:53 PM
1995 Ford F-350
Oldbird, I used an angle grinder, first with a cutoff wheel then a grinding wheel, to cut down my bracket. It went fairly easily and quickly; I think that's the proper tool for the job.
  #28 (permalink)
Old 06-18-2012, 06:07 PM
Ya, after the rough cuts I used a grinding wheel to smooth things up. Forgot to mention that Darin.
Pete said he did his in his pickup, I wasn't that brave. Its only three or four bolts after you set the alternator to the side.
__________________
Glenn
Tags
250, 73, agle, ford, pulley, rubbing, tensioner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
