Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 06-17-2012, 05:33 AM
bob1987f's Avatar
bob1987f bob1987f is offline
Garage is empty, add now
bob1987f is starting off with a positive reputation.
05 EB check tire pressure light
Check tire pressure light stays on in my buddies 05 Eddie Bauer expedition but pressure is fine. I hooked my scanner up but it didn't read any codes ...is there a reset procedure for that light? Thanks
  #2 (permalink)
Old 06-17-2012, 09:34 AM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Yes, but it requires the correct scanner. A standard scanner won't cut it.
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #3 (permalink)
Old 06-17-2012, 12:00 PM
alloro alloro is offline
alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.
The battery in that sensor could be dead. It is about 8 years old by now and they're only supposed to last 10 years.
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
  #4 (permalink)
Old 06-17-2012, 06:45 PM
bob1987f's Avatar
Who's got the correct scanner the dealer? And where's the sensor located? Thanks
  #5 (permalink)
Old 06-17-2012, 07:39 PM
Yes the dealer will the scanner and the sensor (and battery) is on the valve stem inside the tire. The tire has to be broken down to access it. Some tire places also have the scanner so that they can replace the valve sensors too.
__________________
  #6 (permalink)
Old 06-18-2012, 03:48 AM
broncoholic's Avatar
broncoholic broncoholic is offline
broncoholic is starting off with a positive reputation.
Don't forget to check the pressure on the spare tire. This is often overlooked with the tire pressure monitoring system light.
  #7 (permalink)
Old 06-18-2012, 05:56 AM
The spare usually doesn't have a sensor and will trigger the light when the spare is installed.
__________________
  #8 (permalink)
Old 06-18-2012, 12:46 PM
If you don't have the right type of scanner, you're wasting your time.
__________________
Tags
03, check, dealer, expedition, ford, light, pressure, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
