Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 06-17-2012, 04:08 AM
Asytole61 Asytole61 is offline
Garage is empty, add now
Asytole61 is starting off with a positive reputation.
Fuel contamination?
Suspect fuel contamination with my 97f-250 because of issues with other vehicle (non diesel). Think this was done 3 weeks ago. Noticed hard starting, truck would catch and start after prolong cranking period. Never happened before. My 1987 5.0 mustang started to run rough( missing, hard start, cutting out about the same time as isue with truck developed. fuel from mustang showed unknown contaminate(clear swirl like substance and small granueles in fuel. Both vehicles have non locking fuel caps. More worried about Truck. Don't drive either vehicle extensively, usually just start and run them around block (neighbors are haters) Would appreciate suggestions on truck worried about damage. Thanks
  #2 (permalink)
Old 06-17-2012, 05:00 AM
Chris56ford's Avatar
Chris56ford Chris56ford is offline
lost
1997 Ford F-350
Chris56ford is gaining momentum as a positive member of FTE.
That is horrible and whoever did it deserves to be taken behind the woodshed..... First thing, I would notify Law Enforcement if you suspect someone put something in your tank. They may take a sample and have it tested. After that is taken care of I would drain your tank and fuel bowl and get some fresh fuel in both, also replace the filter. I would figure out what was in the fuel before I tried to run the truck much. That's my 2 pennies, I know the other guys will have more/better info for ya. Wish you luck with your truck and finding out who is messing with it!!
__________________
Chris
-1997 F-350 4x4,CC,LB,Powerstroke,5spd,216,000 miles,6637 intake,F5 DP-Tuner,3" DP,4" Diamond Eye exhaust,EBPV delete,IH bellowed up-pipes,HPX,Borg Warner TP38 1.0 housing,Southbend SMF/clutch kit,Autometer gauges,6.0 fan,Cooper ST Maxx 285/75/16.
-2007 Harley-Davidson Streetbob, FXDB
  #3 (permalink)
Old 06-17-2012, 10:10 AM
fordpride's Avatar
fordpride fordpride is online now
Never done with mods
1997 Ford F-250
fordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to behold
Yep drain the tanks, dissconnect the the fuel lines from the engine and blow them back to the tank
__________________
Mike. 97 F250 totaled 11/19/12 B.E.S.T. map Louisiana FTE Member Map
2012 Ram CC 1500 5.7 Hemi
Diablo sport trinity hemi fever tune, 87mm throttle body, BBK headers, HF cat, 14" magnaflow, AFE intake, 180* T-stat. All waiting for time to be put on.
When married you have two simple choices. You can be "Happy" or you can be "Rite" you can't have both
  #4 (permalink)
Old 06-17-2012, 07:55 PM
Fuel Contamination
Thank's for reply fellas. Chris your truck is a sptnn image of mine . same ride height,wheels, color. First truck i ever had and probably the last. Again i'm only worried because of the mustang. The truck will start and run without bucking or smoke. Friend of mechanic friend of mine said it could be anything from the inj pump to the injs , it's up there in mileage.
  #5 (permalink)
Old 06-17-2012, 08:27 PM
fordpride's Avatar
1997 Ford F-250
Not to be a azz but find a new mechanic these trucks don't have an injection pump. The injectors are fired off of a high pressure oil system. Get the fuel system cleaned out and if you still have a problem then start chasing it down. You cant tell if the truck has other issues if it's running on bad fuel.
__________________
  #6 (permalink)
Old 06-17-2012, 08:42 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld has a very good reputation on FTE.ReBilld has a very good reputation on FTE.ReBilld has a very good reputation on FTE.
If someone pours something in someone's fuel tank it's usually sugar. If you are certain that someone has put something in your tanks, you definitely need to drain and flush the fuel system, change the fuel filter and fill the fuel bowl with fresh fuel before restarting. If it is sugar, it won't hurt the engine, but I'd get what ever it is out of the fuel system ASAP!
__________________
Bill
'97 F250 ECSB, 4x4, ZF 5spd, 4.10, Rosewood Stage 2s, T500, TS chip, e-fuel, D60 swap, 6637, EBPV delete, CCV mod, 3" dp to 4" straight pipe, Valair clutch, bellowed up pipes, Glow Shift gauges, Scangauge, diy HPX
'92 F350 CCLB, 4x4, ZF 5spd, 4.10, 460 gas to PSD conversion project truck
  #7 (permalink)
Old 06-17-2012, 09:45 PM
Thank's fellas, ford pride, your not an azz, I'm new at this and on a slow learning curve. There is a great deal of information on this site and i appreciate the help. Again i'm not 100% positive on the contamination issue. Truck has 216,ooo miles on her with no major problems(yet).The issue is that it takes a little longer to kick over from cranking. Once started and after that usual 7.3 crackle, it idels fine and there is no smoke. So your right there may be other issues with the prolong cranking. Damm ! I wish i didn't like my truck so much!
  #8 (permalink)
Old 06-17-2012, 09:49 PM
ReBilld's Avatar
Welcome to FTE by the way!
__________________
Bill
  #9 (permalink)
Old 06-17-2012, 10:22 PM
fordpride's Avatar
1997 Ford F-250
If you think someone may have messed with the fuel I would clean it out. You don't want to play with bad fuel since one injector in these truck can cost $350.00.
I would also pull the batteries and go have them load tested
__________________
  #10 (permalink)
Old 06-17-2012, 11:20 PM
Again, excuse my inexpertice, but what would load testing the bateries show? Batteries are about 3 yrs old. Truck is not extensievly driven. At times in the past i would disconnect them both completely for 2 months at a time. ,hook them up and trk starts with no problem. Seems to crank a little faster now ,but a little longer in catching to start. This was my concern before i suspected again suspected a bad fuel issue.
  #11 (permalink)
Old 06-18-2012, 12:20 AM
Seabiscuit-P3's Avatar
Seabiscuit-P3 Seabiscuit-P3 is online now
Seabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud ofSeabiscuit-P3 has much to be proud of
My 2 cents worth might only be worth a penny but here it is:
Resolve any fuel issue before you attempt to run the truck again, just as explained by the others! If you are satisfied/convinced the fuel is not contaminated, the filter is clean etc., etc., you could try some Diesel Kleen. Gray bottle, warm weather. White bottle cold weather. Sitting for long periods of time can cause some problems in the diesel and fuel system without any outside help. What were the outside temps when you had/have this problem?
As to the batteries,
You should load test your batteries to make sure they are putting out ample cranking amps, and they should be close to, if not equal with each other. If one is low it can/will cause the other to equalize with it. 3 year old batteries used as you described (actually not used) need to be checked to eliminate them as a source or contributing factor to the problems. 750 CCA is the recommended minimum IIRC. A lot of guys are using 1000 CCA or better.
Low or bad batteries are also hard on the alternator. If they have not been used for an extensive period of time, I would put the battery charger on them before I connected them back up and started the truck.
As far as disconnecting the batteries, from the Ford Manual:
"Because your vehicle’s engine is electronically
controlled by a computer, some control
conditions are maintained by power from the
battery. If you ever disconnect the battery, install
a new battery, or experience a dead battery, you
must allow the computer to “relearn” its idle
conditions before your vehicle will idle at its
best. To let the engine do this, apply the parking
brake, put the gearshift in Park (automatic
transmission) or Neutral (manual transmission),
turn off all the accessories, and start the vehicle.
Let the engine idle for at least one minute.
If you do not let the engine relearn its idle, the
idle quality of your vehicle may be adversely
affected until the idle is relearned. Your vehicle
will eventually relearn its idle while you drive
it, but it takes much longer than if you use the
previous procedure."
__________________
Jim - 1996 F250 PSD SuperCab 4X4, Fender Flares, Auto Hubs, E4OD, C5 4.10 limited slip, Carr Hoop II steps, Warn XD9000i Winch & Trans4mer brush guard. Pretty much stock.
To join the Oregon Chapter, click HERE
There cannot be a crisis next week, my schedule is already full! (Henry Kissinger)
In the first place God made idiots. That was just for practice. Then he made Congress. (Mark Twain, slightly modified)
  #12 (permalink)
Old 06-18-2012, 12:37 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.oldbird1965 has a great reputation on FTE.
I had a good link to JC Whitney locking gas caps but it went south. I have thought about getting some but never did. A quick search on their site showed these but I'm not saying that they will fit. When I was young I had a 67 Buick Riviera and some jerk sugar tanked me!!
__________________
Glenn
The Mule-96 2WD F250 EC/LB auto, Lots of Mods!! Semi retired, still runs great after years of pulling!!
The Mare 97 dually cc, T4 & s366 turbo, stage II's, IC, studs, springs, pushrods, John Woods auto, 4:10 LS, efuel, FS2500, HVHF IDM, IH water pump with filter, 6.0 trans cooler, 6.0 fan, MBRP 4", SD dual tensioner, 6637, 220 amp alternator, powermaster starter
  #13 (permalink)
Old 06-18-2012, 04:26 PM
ReBilld's Avatar
Quote:
Here you go Glenn, get one of these! LOL!!
Click the image to open in full size.
__________________
Bill
  #14 (permalink)
Old 06-18-2012, 06:02 PM
That looks good Bill, real stylish!!
__________________
Glenn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
