272 Y block Oil filter adapter kit - Ford Truck Enthusiasts Forums
Old 06-16-2012, 10:33 PM
Osubuki's Avatar
Osubuki Osubuki is offline
Osubuki is starting off with a positive reputation.
So I bought a oil filter adapter kit from D Carpenter for my 272, to allow me to install a spin on type filter, no instructions came with it.
Do I have to remove the original threaded unit out of the side of the block and then reinstall this new contraption, or is this supposed to just thread into the existing unit? After doing some internet searching I have seen this go both ways, none were a clear example of a 272.
If I do have to remove it, is there a trick to it, it is a very shallow bolt head and the socket just wants to strip off?
Thanks in advance if anyone else has done this on theirs and may have some insight.
Old 06-17-2012, 05:44 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
All Y blocks = first you will have to grind off the bevel on the socket so it
is flat for this rather thin hex, thats about it, make sure its perfectly clean
"0" ring must be a perfect fit and make sure the drain is top it should be
stamped "top" check for leaks last one I did came from Napa.
Installing an AMSOil Dual Remote Oil Bypass kit on 4.0l asavage Aerostar 14 12-01-2016 08:44 PM
460 4x4 oil filter adapter whiskey runner 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 02-10-2016 03:52 PM
272 vs 292 ireding Large Truck 1 04-23-2013 12:35 AM
AMSOIL BYPASS install thread. oreocreaming Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 09-19-2010 06:02 PM
272 engine code dylan1952 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-02-2010 09:39 PM
Tags
1960, 69, 83, adapter, air, attachment, block, cleaner, f250, filter, kind, oil, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
