4.6 wiring harness???
Does anybody know how much of the wiring harness I would need from a 07 crown Vic to make sure I get the motor running with efi? I'm talking to a guy about buying the motor with motor wiring harness and computer but don't know if I need more of the wiring?
Thanks
Mike
Thanks
Mike
I dont really have the answer your looking for... but If I was contemplating this, I would get as complete of a harness as possible.
Then call dakota digital and have them make a cluster to work with the combo and run with it.
Power windows, locks, modern radio, a/c components, fues panel, etc etc...
Get the wiring schematics from the crown vic and start slicing and dicing to make things fit.
just my 2 cents.
just my 2 cents.
The price for the harness is $850 at thedetailzone.com web site. Your ECM would have to be reprogramed to work. I used the harness for a 1995 4.6 and am well satisfied spending the money for it. You get every circuit that was in the original ECM, not just what is needed to run the engine. Sounds pricey but after looking at the original harness to work the engine and transmission I thought it was a good investment.
New to forum so
I found these web sites so I hope they have what you need. I was given a 89 Lincoln Town Car with low miles (65000) running great, just started it up today after to 3 years sitting out back, free is good. I wanted to us the EFI and AOD, not so sure about the air ride suspension. Have fun and good luck. Ford EFI Swap and Fuel Injection Technical Library
f150hotrod
06-07-2005 10:25 AM
