Carb dump, gas everywhere - ?!?
#47
Had to check eBay, one never knows what little gem might turn up.
Here's a peach. Includes vintage gasoline.
IN LINE FUEL FILTER MANY USES | eBay
#48
To catch everyone up - my carb mounting bolts worked themselves loose, throwing the carb off kilter, and probably jamming the float - resulting in a big gas leak. That issue was fixed yesterday. This thread has evolved into the best place to put a filter, as the factory configuration has it poised directly above the exhaust manifold, a situation which has caused in-filter fuel boiling for some members.
At this juncture, we're redesigning the system, trying to reach a consensus as to the optimum location for the fuel filter on an inline 6-300.
All opinions are most welcome!
#49
I hope you mean that...because I think I am going to be the token annoying guy in this thread.
Again...maybe I missed it, but I didn't see anyone talking about fuel boiling with the filter threaded into the carburetor. Someone mentioned having that issue with a filter located where yours is, which makes sense...it's pretty close to the engine. But as high as the carb sits I can't see a filter up there getting that hot, and if it was a problem I suspect Ford would have relocated it over the many years that they did it that way.
#50
I believe you are wrong on your diagnosis, I don't think the bolts being loose caused the float to jamb, I believe it was dirt, which is why we are discussing different filtering ideas. Someone jump in if they think I am off-base on the root cause of his problem. I don't like the little bits he described that he sucked out of the bottom of the carb.
If my truck can run reasonably well with that, I would be very surprised if the small amount of debris WilleyJoe found could take down his entire truck. I'm not saying it can't happen, mind you...just that I'd be surprised.
#51
The filter position shown in the latest pics, is right over an opening in the intake, and that happens to be there to allow for the exhaust manifold to mate up with the head. Much more chance for the heat to do what it naturally want to do, rise up. This means the heat will be focused on anything directly over it, and can result in the filter having fuel boil inside it.
#52
I'm going to add a screw-in filter at the carb, because I'd rather spend a few bucks than deal with that leak again anytime soon.
The black specks shown in that cup photo were like fine silt, smaller than grains of sand; it took me six photos to get that shot, and they disappeared when I swirled the gas around in there. It may well be crap from the new fuel pump and rubber fuel lines I installed earlier this year.
Of interest - the Fuel Filter page from the 1981 Shop Manual.
#53
It doesn't take much at all to cause the needle/seat to leak, big time. Rust silt doesn't seem to do it because I, too, could scoop some out of my carb before I went to two filters, but I didn't have any flooding. However, rust silt will plug a 2150's accelerator pump discharge nozzles - for sure.
Anyway, grains of "stuff" aren't good and if they get stuck in the softish material of the needle will cause big problems.
bghnkinf250
08-26-2009 09:08 AM
Boss F150
12-16-2006 05:31 PM
Hokie on a Harley
05-19-2002 11:26 PM
