351 swap, not an engine question - Ford Truck Enthusiasts Forums
Old 06-16-2012, 03:01 PM
sm7482's Avatar
sm7482 sm7482 is offline
sm7482 is starting off with a positive reputation.
My 292 is really tired, it seems to be more expensive to rebuild it then grab a 351 to put in it. Ive searched on here and google, but i cant find quite what i want to know. I dont want an automatic, its out of the question. It seems most the people swapping this motor in go with an automatic. What manual transmission can i use? My truck is a 1959 f250. its 2wd, are the 4wd trannys different? I read something about a toploader 4-speed not being ideal for a truck due to the first gear ratio? one post had a comment along the lines of "unless you have a 3.98+ rear end and dont do freeways, its not ideal for a truck". I have a 4.56 rear and would like to freeway cruise so? thanks guys.
Old 06-16-2012, 03:05 PM
sm7482's Avatar
oh, and the reason i ask about the 4wd difference is because i can get a ford BB 460 motor for cheap but it comes with a manual 4wd tranny. i have a 2wd truck so i dont know if i could even get a 2wd manual tranny for the 460? im more concerend with tranny options then the engine. thanks.
Old 06-16-2012, 04:23 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
You want a 4x2 trans. The tail on a 4x4 trans is meant, in most cases, to bolt to a transfer case. That isn't going to work for 4x2.
The 351w can accept just about any Ford issued manual trans. You will find it mated to the ZF 5 speed in later model PU trucks.
The car performance 4 speeds have a 2.78 first gear, or 2.32 if you get a close ratio. 4th is 1:1.
The ZF has a 5-something first, and an OD 5th, imo better for trucks like yours.
The ZF uses an integral bell and an internal hydraulic throwout bearing. Your truck already has a hydraulic clutch, right?
Some fiddling will have to be done to marry the '59 master to the later model throwout, but a little trial and error never hurt anything but the pocket book.....
If you go with the 4 speeds, you will have to find a later SBF/butterfly pattern bell that will accept the hydraulic slave for the throwout. 1983-4 and up F series would be the target, with the 300/302-351w.
Domestic Truck Tranny Guide
Old 06-17-2012, 03:16 AM
sm7482's Avatar
Awesome!!! exactly what i wanted to know! i like the sound of the zF 5 speed from later trucks. what years had them? what models? and yes! i have a hydraulic clutch, all i would need would be new hose i would think. i can get windsor mounts from my catologue but im guessing ill need to fab up a tranny mount correct?
Old 06-17-2012, 03:19 AM
sm7482's Avatar
Im guessing the 351 probably wouldnt bolt up to the tranny on my 292 right?
Old 06-17-2012, 09:25 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Nope.. different engine family so different belhousing bolt pattern. With the axle gearing you have you really need a trans with overdrive so you should look for a late model T5(Mustang), M5OD(F150), or ZF-42(F250/F350) from a vehicle with a 5.0 or 5.8 V8 or 4.9 I6. All these 5-speed transissions have an 0.8:1 OD ratio and the ZF also has a deeper first gear ratio.. but that's not going to be necessary with the gearing you have.. you'll be skipping 1st a lot anyway.
Old 06-17-2012, 08:29 PM
willowbilly3 willowbilly3 is online now
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
My pick wouldd also be the ZF. I have one mated to a 300 and love it. Also the lighter duty Mazda 5 speed from the F-150 and light duty F-250 would bolt up too. It isn't a bad transmission except it has an insanely high reverse ratio. Backing a trailer up even a slight slope requires slipping the clutch. There were a few other 3+1 overdrives Ford used in lighter duty pickups and vans too. I have a couple examples. One is basically a cast iron toploader 4 speed that they did a little monkeying with and came up with overdrive. Another one is an aluminum top shift style but I can't remember the model of it. They were used late 70s to mid 80s IIRC.
1966 f250 engine,trans,brake swap from 1970 f250 rangerdanger70 1961 - 1966 F-100 & Larger F-Series Trucks 7 08-29-2016 07:53 PM
Guidance on setting up for freeway speeds twozzie 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-23-2016 09:56 PM
1973 Transmission swap Sportsterengr 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-15-2016 02:41 PM
Paint job ideals? Pete Kildow Paint & Bodywork 10 05-12-2015 05:47 PM
What Gear Ratio? davewave649 1961 - 1966 F-100 & Larger F-Series Trucks 18 02-18-2010 03:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
