Tailgate Step Delete - Ford Truck Enthusiasts Forums
Old 06-16-2012, 08:40 AM
sgrol sgrol is offline
sgrol is gaining momentum as a positive member of FTE.sgrol is gaining momentum as a positive member of FTE.
New truck off lot came with tailgate step which I didn't want. I work off of my tailgate and need a rather flat surface that the tailgate step handle screws up. Has anyone removed the handle? The step itself is inside of the tailgate and doesn't bother me. I was thinking of removing the handle before I get the bedliner installed so the liner will cover up the screw holes.
Old 06-16-2012, 09:16 AM
Averill7's Avatar
Averill7 Averill7 is offline
Averill7 is gaining momentum as a positive member of FTE.
Someone has already removed the step assist handle.
Old 06-16-2012, 10:40 AM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
Yep, just went to the dealer and got the access panel cover from a non-step tailgate and swapped everything out before having it line-x'd. The step is still in there, which admittedly does come in handy, but not having the pole in the way of loading is very nice.
Old 06-16-2012, 02:29 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Better option is MAKE money on the swap as someone in your area will LUST after a step gate
Old 06-16-2012, 09:11 PM
Quote:
Problem with this is that I would have to swap out the whole tailgate as the step is integrated into the tailgate mid section. The step itself is not in my way, I just need a relatively flat surface to work off of when the gate is down and the 'flagpole' is in the way..
Old 06-16-2012, 09:37 PM
jdadamsjr's Avatar
understand - and yes, but just offering what I've seen many want good luck !
Old 06-16-2012, 11:01 PM
doublenot7 doublenot7 is offline
doublenot7 is gaining momentum as a positive member of FTE.doublenot7 is gaining momentum as a positive member of FTE.
Well if you decide to loose the whole tailgate and it is blue, I will swap you.
Old 06-17-2012, 03:45 AM
Shelby-GT-500 Shelby-GT-500 is offline
Shelby-GT-500 is gaining momentum as a positive member of FTE.
I'm in AZ I have a Brown truck if you want to swap!
Old 06-17-2012, 07:52 PM
jdadamsjr's Avatar
See, I told ya
Old 06-17-2012, 08:32 PM
See, I told ya
You were right on. Guys, I am going to keep the tailgate with step just going to delete the pole. Thanks for the offers. BTW, color is autumn red. Closest I could get to Aggie maroon.
I removed the pole and plastic liner today to see what I would need to do. Exposed several large access holes that I will make a steel plate to cover and then Line-X it all.
Old 06-17-2012, 08:41 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
Quote:
I don't mind my step, but the pole sucks! Its all scraped and rusted from the carbides on my sleds when I load them, gonna have to do this delete as well.
How much did the non-pole panel cost you?
Old 06-17-2012, 11:01 PM
screwy's Avatar
I think it cost me around $90.
Old 06-18-2012, 03:29 AM
bookem15 bookem15 is offline
bookem15 is starting off with a positive reputation.
purchase a table ? sorry somebody had to say it...
Removing the tailgate Handle? cr2crf 2009 - 2014 F150 2 07-09-2013 05:50 PM
How do I remove the tailgate assist handle and replace the lid with a normal peety37 2009 - 2014 F150 11 06-22-2012 04:57 PM
Tailgate step & handle??? ackeiyword 2009 - 2014 F150 27 05-18-2012 11:41 AM
Removal of tailgate handle T.Mainus 1999 to 2016 Super Duty 2 03-17-2010 07:17 PM
Tailgate lock swap papadelogan 1999 - 2003 7.3L Power Stroke Diesel 9 12-14-2009 11:09 AM
Tags
2008, access, bar, cost, cover, end, f250, f350, flat, ford, gate, handle, hole, lariat, removing, step, tailgate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
