Ring and pinion change $$$ - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-16-2012, 12:06 AM
slo ranger trk slo ranger trk is offline
slo ranger trk is starting off with a positive reputation.
anyone out there have any idea about the costs of
a R & P change shop costs ? that's if i have all the parts there for them to put it together.. l/s diff, master assembly kit, r & p, c clip eliminator kit, and a deep sump rear cover .... any help would be helpful ..
thanks guys,
mahalo, Ray
ps. am planing to use a ford motorsports l/s diff & 4.56 r & p..
any sugestions ill be helpful =)
Old 06-19-2012, 12:07 AM
Pkupman82's Avatar
Pkupman82 Pkupman82 is online now
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
It's probably safe to say you will be really close to $400 or $500 in parts. I would bet by the time all is said and done you will be around $800 to $1000 total... I know OUCH! Have you ever concidered learning how to set up your own gears? I have have done several of them over the years, even did it for a living for a short while.
John
Old 06-19-2012, 07:12 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
I charge $300 if you supply the parts.
Old 06-19-2012, 08:04 AM
bratman2 bratman2 is offline
bratman2 is starting off with a positive reputation.
Quote:
Sorry for the hijack but how much do you charge to install LS if I have purchased the unit?
Differential swap, need help please. tmajikman Aerostar 7 08-05-2013 01:09 PM
misfiring again! dsrussell555 1997 - 2003 F150 13 02-04-2008 07:27 PM
Limited Slip Front Diff kellar 1987 - 1996 F150 & Larger F-Series Trucks 3 06-05-2007 07:05 PM
LS in a Dana 44 mikeyswood Offroad & 4x4 19 03-19-2007 11:11 AM
8.8 l/s differential, mustang - f-150 alwaysmessedup Clutch, Transmission, Differential, Axle & Transfer Case 1 06-24-2003 12:36 AM
Tags
08, cost, f150, ford, pinion, ring, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
