waterpump bot length/location 1994
water pump bolt pattern
Thank you so much,Peter, for your reply. On mine, two of the longer bolts were 1/4 inch shorter.
Do you know where these shorter ones go? Can I install these 11 bolts and thighten them before putting on all the brackets for the AC, tensioner, ALt, power steering and air pump? I don't quite remember the exact sequence. Thank you again. Bill
So there are two different "long" bolts... I can't remember where they go though. I think if you just test fit the pump you should be fine. I don't think either accessory bracket shared any bolts with the water pump, but maybe I can't remember that either.
Don't forget to install that water pump backing plate.
Thank you, you helped me. I did have two bolts switched. I tried measuring depth of holes in block plus thickness of pump ad backing plate. If there were only two sizes, 2 1/2 and 4 1/4, it probably wouldn't be a problem, but two were 4 inches. Now, I have to wait for the pump to arrive. Most of these bolts were tough to get out. I was very converned about breaing them off in the block. I P B blasted all bolts. That stuff is great. Thanks again. Bill
1993460F250
03-30-2014 09:06 PM
RRranch
02-11-2010 05:38 AM
bassproguy07
04-03-2007 01:27 PM
