Fueling problem - '03 F150
My 2003 F150 extended cab (4x4, 4.6) won't take fuel without overflowing and splashing gas all over the place. Even if I run the pump at very low rate it still splashes back.
I replaced the tank last fall and it worked fine afterward for several months but the last few times I tried to fuel it I have had problems. I don't drive it too much so I only need to fuel it once a month or so.
Any thoughts on where I should start looking?
Thanks.
Thanks.
Don't worry, it takes a lot to insult my intelligence.
The pumps do use auto shutoffs but that doesn't stop the fuel from splashing back around the nozzle but it does it after the pump stops pumping as if the tank were full. Two different stations, several different pumps so I have ruled out the pump as the issue. And I know the tank isn't full since it is a 24 gallon tank with over 350 miles since the last fillup. Gas gauge works.
As to what has changed, no telling. I did the tank and had to change the sensor since I broke the old one when I took it out of the old tank. But fillups worked fine for several months.
Any ideas appreciated.
I don't recall a flapper valve when I swapped out the tank. It seems like the tank is pressurizing somehow by the addition of fuel. How do these vent during fueling? Maybe a kinked hose or something?
AS you put gas in the tank, the air inside that is displaced has to get out. A couple inches from the top there is a 1/2 inch rubber hose on the neck that lets the air out. You have a check at the top that helps seal the filler nozzle to the neck to keep the fumes inside. That also causes it to pressureize as the air cant get out.. Take off the rubber hose and check for blockage or kink.. Leave it off and test fill.
Thinking about it though, I think I changed that piece of hose with a new one so maybe I made it too long and it somehow got kinked. Hopefully it is that easy.....
Thanks everyone.
Dzozer
2009 - 2014 F150
29
07-03-2012 09:15 PM
chrismartinez0
07-01-2010 01:25 PM
Manwith3fords
15
01-03-2007 08:19 PM
