Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-15-2012, 06:09 AM
Supercab Supercab is offline
Garage is empty, add now
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Wink "Stroage" of Bio Diesel??
How long will Commercial Bio-Diesel keep fresh in my truck's fuel tank?
I just put in a 20% blend and was planning on running 2 tanks of IT, then going to 50% for 2 tanks, then right to B99.
I use about a tank (38 gallons) per month in my '99 F350 7.3 truck.
My friens says the BIO will go bad way before regular Diesel will inside the tank.
(I understand all the stuff about the BIO cleaning all the crap from the fuel system) I did this once before with 20% for 2 tanks but didn't continue because at that time the BIO was MORE than regular Diesel and I had to go way out of my way to get it-now the B99 is 40cents less than regular diesel here and I don't have to worry about any extra lubrication additive.
Comments, Thoughts?? Thanks!!
__________________
Support FTE
  #2 (permalink)
Old 06-15-2012, 07:07 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Welcome to the bio forum! Well made (ASTM) commercial bio should be fine for up to 6 months. The biggest threat to biodiesel is air. Keeping tanks as full as possible and keeping the bio to air interface as small as possible will allow it to last just fine with your warm temps.
I have 1lt jars of bio I made 6 years ago that are full to the cork with no air, on my lab shelves, and they are just a good as when I made them.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 06-15-2012, 04:39 PM
Thanks for the warm welcome!! I appreciate it!! I've been a member of the FTE for almost 15 years now, first active in the '73-'79 forum, then the '87-'96, then to the '99-'03 PSD forum-(I have a LATE '99 F350 XLT CC Dually 7.3 now) and am trying to learn more about Bio fuels........my truck has been meticulously maintained by the first owner and myself-has just 112k miles on it now, trying to fuel it cheaper and stop the hasstle of having to add an extra lubrication additive at the same time.
I am told by the fuel supplier (Glover Oil) in Melbourne, Florida that at current the Bio-Diesel is made from beef tallow from out west-they used to have soy bean stuff about 3 years ago......am I safe with a CLEAN fuel system to start with in going to Bio gradually and ending up with B99 on my 6th tank from now? do the 7.3s like 99% BIO?
__________________
Support FTE
  #4 (permalink)
Old 06-15-2012, 11:04 PM
binuya's Avatar
binuya binuya is online now
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
Quote:
5 years ago I did the same thing by gradually going up in concentration over the course of several tanks until I filled it with B100 within a couple months, and had no problems with any sort of filter plugging with built-up deposits. I had also checked the fuel filter twice to find nothing. So I presume I had a clean tank and fuel system to begin with. I am just over 150K miles with 30K of those miles on B70 and up. Just a couple months ago, I dropped my tank to do the hutch and harpoon mods, and was amazed at how spotless it was in there. Even the mixing screens were immaculate, with no junk on them whatsoever. So as far all as those warnings about filter plugging when running biodiesel, it all depends on the condition of you fuel system to start with.
I think 7.3 PSD's run outstandingly well on biodiesel. All of my Blackstone OA's come back great with no indication of any sort of oil dilution. My latest emissions test outperformed the test results of my 1995 Mercedes E300D in the opacity reading. My 7.3 got an 8% opacity, while the Mercedes got 15%. To me this means more complete combustion.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #5 (permalink)
Old 06-17-2012, 06:11 AM
Great info guys!! Thanks very much!
__________________
Support FTE
  #6 (permalink)
Old 06-25-2012, 09:19 AM
BioBilly BioBilly is offline
BioBilly is starting off with a positive reputation.
fabmandelux is correct. The standard is ASTM 6751 and the property you refer to about "fuel going bad" is oxidative stability. The ASTM test method for oxstab is EN15751. Oxstab depends on many things including the process used to esterify the biodiesel as well as the raw material used to begin with (tallow, waste vegetable oil, poultry oil, or virgin plant oils. Simply speaking, it is a measure of haw fast it will become rancid like the bacon grease you leave in the skillet too long. Properly treated raw oil that is properly processed will give you no problems.
  #7 (permalink)
Old 06-28-2012, 03:31 AM
Got a tank of B99 yesterday, have driven 35 miles so far, all seems good so far....20cents cheaper than dino and no having to add extra lubrication additives!!
__________________
Support FTE
Tags
2001, 73, added, biodiesel, diesel, soy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
