Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.7, 3.5 and 3.0 Duratec V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
3.7, 3.5 and 3.0 Duratec V6 Forum for the 3.7, 3.5 and 3.0 naturally aspirated Duratec V6 Engines
  #1 (permalink)
Old 06-15-2012, 01:25 AM
Farm Mechanic Farm Mechanic is offline
Garage is empty, add now
Farm Mechanic is starting off with a positive reputation.
2006 3V into a 1998 with 2V PCM
I had added this to another thread, referenced below, but thought I would start a new thread. It seems exciting and I hope it can help others contemplating this task.
I have put a 3V V10 into a 2V chassis {motorhome}.
Engine runs for about 3 or 4 seconds, purrs like a kitten, then dies. Restart, same thing. After a few consecutive restarts {5 seconds or less in between} it won't start at all, turns over but won't ignite. Let sit for 10 or 15 seconds, then it would start again running for only 3 or 4 seconds.
No "Check Engine" codes coming up. Maybe not running long enough??
Any help would be appreciated.
A similar post that has been helpful and encouraging:
http://www.ford-trucks.com/forums/85...l#post11954681
  #2 (permalink)
Old 06-27-2012, 04:24 PM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
You would get a LOT more response posting this dilemna in the V10 section... This is for duratec v6 dohc engines of various displacements, and most don't know beans about a v10.
That said, I'd put a fuel gauge on the injector system and watch pressure. You may have something telling the system to shut down the fuel pump {pressure regulator gone bananas} or a filter plugging problem or ???
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #3 (permalink)
Old 06-27-2012, 04:37 PM
Oops...
Thanks for responding, I am new, I did not realize until reading your post and loooking up and seekin that this was in the wrong area of the Forum I thought I had selected V10 but must have clicked away on the wrong one in the end.
The problem was a vacuum leak on my throttle body.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
