Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > 2011 & Newer Explorer
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
  #1 (permalink)
Old 06-14-2012, 11:26 PM
BigBadBob BigBadBob is offline
Garage is empty, add now
BigBadBob is starting off with a positive reputation.
A/C suddenly stopped blowing cold air!
I was driving through a residential neighborhood, probably going about 35mph, when suddently the a/c stopped blowing cold air, then it blew hot air for about 3 minutes, then blew cold air, then hot again. FInally, I pulled into the nearest parking lot and turned the engine off. I waited for about 5 minutes, then started the engine again. This time, the a/c seemed to work fine. What the heck is is going on? Does this have something to do with the TSB or recall that some of you guys mentioned on the previous thread? Are the contacts on the cooling fans contaminated? What do you all think?
__________________
2012 Explorer 3.5L
2013 Mustang GT
  #2 (permalink)
Old 06-28-2012, 07:04 PM
cparks cparks is offline
2011 Ford Explorer
My Garage
cparks is starting off with a positive reputation.
Was the electric cooling fans running? Had the same issue last year with my 2011 and they had to replace the cooling fan assembly.
__________________
Clayton Parks - Michigan
2012 Ford Raptor SuperCrew Supercharged 6.2
1957 Ford Ranchero 4x4 428 project
1960 Ford F250 4x4 521 stroker project
2000 Ford Excursion 4x4 V10
2013 Ford Escape
Tags
10, 2008, ac, air, blowing, cold, f250, hot, min, sport, stopped, stops, trac, truck, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
