Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 06-14-2012, 06:19 PM
we56 we56 is offline
Garage is empty, add now
we56 is starting off with a positive reputation.
driveshaft angle?
Hi, got a question about driveshaft angle i put a narrowed rearend in my 57 and pinion is over to the right side of chassis by a couple of inches am i going to have issues with u-joints or vibration? thank you
  #2 (permalink)
Old 06-14-2012, 08:27 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
As long as the yokes are still parallel to each other, there should be very little vibration and mild strain on the joints. Straight of course, is preferred.
  #3 (permalink)
Old 06-14-2012, 10:12 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
We56
Here is a link you can wrap your head around!
DRIVE LINE PHASING
Good luck in your quest.
Heres some more I did a search on our sister forum 48-56
As a general rule, you MUST have a minimum of 1/2 a degree angle on the joints to keep them lubricated. Ideally, it's best to hold the angles at 3 degrees or less for maximum joint life and vibration-free performance. You can run more than 3 degrees, but joint life suffers greatly and you run a greater risk of vibration. You also have to keep in mind when laying out your driveline that the pinion is going to rotate up under load no matter how stiff your bushings and suspension are. Most installers compensate for this by rotating the pinion an extra 1/2 degree to a degree down. This way it will rotate up under load to roughly its ideal angle.
Here's some more light reading about driveline angles with lots of good illustrations:
Free Driveline Assembly Troubleshooting Information
This next one is the official Spicer driveline setup guide and should be considered the absolute authority on the subject:
http://www2.dana.com/pdf/J3311-1-HVTSS.PDF
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #4 (permalink)
Old 06-15-2012, 05:05 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
actually on all trucks the pinion is offset to one side. trucks use the same lenght axle shafts on either driver or passenger side, so this puts the pinion off to one side. on cars it is more important to centre the pinion due to the driveshaft tunnel running down the middle of the car. on trucks it doesn't matter if the driveshaft runs down the middle or off to one side.
rgds
Mike
Tags
angle, drive, driveshaft, explorer, ford, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
