-51 F5 COE project - Ford Truck Enthusiasts Forums
-51 F5 COE project
Old 06-14-2012, 02:41 PM
fordCOE fordCOE is offline
fordCOE is starting off with a positive reputation.
-51 F5 COE project
Hello again from Finland.
I have been trying to work on my new project every chance (not too many) I got last winter. And I thought that I might share some of it. If someone has good ideas etc. Anyway this is what it looked like when I got it home from Michigan. I bought the car from Eaton Rapids, MI. If somenone knows anything about this cars history, I would be very happy. I bought this car from brothers, whose father bought this car as a project for himself. Father has passed away and the sons decided to sell the project.
First I had to figure out what kind of driveline I was going to use. The original flathead six was out of the question, cause gas is about 1.6 euros/litre ( about 8 bucks for gallon). That is why I decided to use a diesel. the next problem was to find a small potential diesel that would have some power, good torgue ang good mileage.
Old 06-14-2012, 03:14 PM
After several candidates I decided to use Mitsubishi`s 3.3TD from a light truck that has about the same total weight 14000lbs. The engine is quite small 4 cylinder turbodiesel, 117 horsepower and 279Nm torque (about 206ft/lbs I think) Smal numbers for V8 guys but this is a good choice I think, cause I would like to drive this truck with a reasonable cost all year. So I ended up byuing a whole truck that I had chop to get the parts I needed.
Old 06-14-2012, 03:25 PM
Some of you might think that why not use the -88 Mitsubishi`s frame and driveline and just change the COE cab to it. That came to my mind but I did not like the idea that my title says -88 Mitsubishi. And one reason is finnish legislation, that would make it hard to use a 50`s cab in late 80`s vehicle. Safety issues etc. Other reason is that these Mitsu frames are often rusted badly, so they would need a lot of work. So I decided to go with the original frame and cab and change/ modify the following:
- Engine and transmission
- Front axle that has power steering
- Rear axle
- All the suspension
- All the brakes of course
Old 06-14-2012, 03:36 PM
Taking things apart is allways fun and fast to do First came of the engine and then I took off the front axle.
Old 06-14-2012, 03:40 PM
Then I had to make some new attachments to join the new front axle to the COE frame:
The rear shackles come to these
Old 06-14-2012, 03:49 PM
With these "modern" axles I can now use 16" wheels, that are much easier to get good tyres, I got rid off the 20" widowmakers, and the whole car came much closer to ground, which is important for the looks
Old 06-14-2012, 04:39 PM
Next job was to squeeze in the new engine and tranny. It was suppose to be a small engine but somehow there is newer enough room to just bolt it in there!!! No room for the turbo, generator, fuel filters, fan, and many other things. They all have to be relocated or modified. But of course when you use entirely different drivetrain, there is lot of modifying to do.
The whole middle floor has to be made a little bit higher, cause I wanted to leave some room for the suspension trave. I do not want to be hitting the oilpan with the front axle.
I will post some more pics when I get a change to sit on the computer again.
Sami
Old 06-14-2012, 05:09 PM
arctic y block's Avatar
arctic y block arctic y block is online now
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Wow!! Cool project. This will be fun to watch.
Old 06-14-2012, 05:26 PM
48fordcoe's Avatar
48fordcoe 48fordcoe is offline
48fordcoe has a good reputation on FTE.48fordcoe has a good reputation on FTE.
Keep us posted your coe will be nice
Old 06-15-2012, 12:11 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Great to see another COE project......have fun building!
Old 06-15-2012, 01:23 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Quote:
That is a fantastic project and it looks like you are having a great time with it. Well done! I think your engine choice is a very good one, too. While you may think the power is low, it's far more than the stock 6 cylinder engine had, at 95 hp and 180 ft. lbs. torque. It'll be good for what you're going to be doing with it. And besides, you can always increase the turbo boost.
Old 06-15-2012, 01:51 AM
Cody_1948's Avatar
Cody_1948 Cody_1948 is offline
Cody_1948 is gaining momentum as a positive member of FTE.
Eaton rapids michigan, I live 10mins away from there, and the cole you have ive seen in person... Wow such a very small world....
Old 06-15-2012, 08:12 AM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Following this one. Very interesting build, and engine choice. What body will the truck run? How will the truck be used?
Old 06-15-2012, 07:21 PM
I have a vision that it is going to be a open bed car hauler with a tilting bed. I have a drawing somewhere that I could show...hot rod flatz rust brown and beige grill...and mostly I am going to use the truck for hauling my own stuff from a to b and to go to work etc. but the idea of a car hauler came from my friend who needed a transportation for this:
Old 06-15-2012, 07:35 PM
After getting the front axle in place it was time to get rid off the rear axle and line the new rear leafs with the front. I bought a laser liner to help the job and I think I got it in a few millimetres accuracy. I think that it is important to get the rear axle lined up with the front kingpins as well as possible, and the rest is adjusted with the 4 wheel alignment.
78 Trailer Special Project HuntinBronc 1978 - 1996 Big Bronco 59 03-08-2016 06:00 AM
'51 COE PowerStroke build MrCarlsonq 1948 - 1956 F1, F100 & Larger F-Series Trucks 93 11-06-2015 09:54 AM
Starting problems (was:Fuel pressure escapes quickly) SamiO Bronco II 40 09-24-2015 12:12 PM
new LN8000 owner in Oz roKWiz New Member Introductions 0 08-10-2015 04:26 AM
Has anyone used 2" lift shackles? Linne 1999 to 2016 Super Duty 60 04-05-2015 08:40 PM
Tags
1947, 410, aligner, axles, build, change, coe, fit, ford, frame, front, suspension, truck, wa, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
