1992 F250 no spark - Ford Truck Enthusiasts Forums
1992 F250 no spark
Old 06-14-2012, 01:42 AM
lilsuzuki4x4 lilsuzuki4x4 is offline
lilsuzuki4x4 is starting off with a positive reputation.
1992 F250 no spark
Hey guys and gals!! I have a 1992 Ford F250 5.8L gas engine, with no spark so far I have tried a ignition Control unit ( the one on drivers fender ) and a coil, still no spark!! What else can I try? need to diagnose not just throw parts at it!! please help!! thanks
Old 06-14-2012, 03:44 AM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
These pages may help you to isolate your no spark, could be a bad PIP
Part 5 -Ford Ignition Module Test. Fender Mounted Module (ICM).
Old 06-14-2012, 07:51 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
X2 That is a pretty good writeup
Old 06-14-2012, 08:53 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
Does the fuel pump run when you turn the key? Have you checked the fuses both under the dash and under the hood? If that all checks out then check for voltage at the coil, should be 12v IIRC on the 'hot' side of the coil (the side the DOESN'T have the condenser/noise filter hooked to it).
Old 06-15-2012, 01:05 AM
AWESOME Thanks guys!!
Old 06-15-2012, 01:07 AM
Quote:
fuel pump kicks in and i have 38 psi at the test port, all fuses good, ill check coil thanks!!!
Old 06-16-2012, 05:58 PM
ok i did all tests, and did them 2 times to be sure, as per the test it point to the PIP sensor. Where is a good place to buy one and can you get it out of the distributor? or replace whole distributor?
Old 06-16-2012, 06:04 PM
Quote:
Replace the whole distributor is easiest
I had terrible luck with the re-manufactured units, so...I went to CarQuest and bought a brand new unit, marked on the box "heat tested" I think it cost me 120.-...
Old 06-17-2012, 02:05 PM
ok got a used PIP sensor, and I have all kind of spark, but still will not start? I double checked timing? suggestions please?
Old 06-17-2012, 02:13 PM
What about the question from pfogle above, can you hear the pump for a second?
Old 06-17-2012, 09:05 PM
yup! and I replied 06-15-2012,post #6 02:07 AM look above
Old 06-17-2012, 09:08 PM
I must be off in timing, any one have a how to find TDC cylinder # 1?
where should the timing mark be on the harmonic balancer on comp stroke?
#1 cylinder is pass side front?
Sorry guys i should get a service manual for this truck
Old 06-18-2012, 03:16 AM
I missed that
Fuel Injection Technical Library Setting the timing
Old 06-20-2012, 12:34 AM
thank-you Slip ford man
Old 06-20-2012, 12:36 AM
so it was PIP sensor, now next days off set my timing and hope she fires
1992 E250 5.8 No spark with SPOUT plugged in Maverick7687 1968-2013 Full Size Vans 1 11-12-2016 07:07 PM
No spark and no fuel CooterJoe 1987 - 1996 F150 & Larger F-Series Trucks 8 08-05-2016 08:27 PM
Body Lift on 1992 f250 4x4 toolmaster 1987 - 1996 F150 & Larger F-Series Trucks 11 09-18-2010 09:41 PM
1992 F250 Code 41??? Bigboyztoys4x4 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 03-16-2010 11:13 PM
1977 ford f250 getting no spark ymirr 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-17-2009 08:34 PM
Tags
1992, 58, coil, doesnt, f150, f250, ford, spark, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
