1970 f100 9" axle shaft??? - Ford Truck Enthusiasts Forums
Old 06-13-2012, 10:59 PM
70 LIGHTNING 70 LIGHTNING is offline
70 LIGHTNING is starting off with a positive reputation.
Hello, I am new here and hope you guys can help me out!
So here is the problem im faced with... I bought a 1970 f100 2wd last year and this last weekend I blew up the rear end in it. I cant find any info on aftermarket axle shafts for this truck at all! I just bought a new 31 spline 3rd member but now I need axles... Who makes them? What is the length of them? Are both sides the same length? Are they the same as any other popular axle, like a 60's Mustang or something?
Thanks for any help!
Old 06-14-2012, 02:42 AM
RichS2659 RichS2659 is offline
RichS2659 is starting off with a positive reputation.
For all things 9 inch, go to the original experts, Currie Enterprises is the answer.
Old 06-14-2012, 07:07 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
Passenger car 9" axleshafts are not the same as F100 and are usually right/left specific. F100 axle shafts are the same right/left.
The original expert: FoMoCo, everyone else is secondary and many of these so-called "experts" are totally unaware of the following:
1968/72 F100's were available with two different 9" rear axles.
One has 28 spline axleshafts (C8TZ-4234-A), t'other has a 9 3/8* ring gear and 31 spline axleshafts (C8TZ-4234-B).
Only five parts are the same 9 vs 9 3/8: Housing gasket, pinion seal, pilot bearing retainer, one pinion bearing and race.
EVERYTHING else is different! // How many splines does your axleshaft have?
Old 06-16-2012, 08:03 AM
They were 28 spline. But I just ordered up a 31 spline 3rd member so now I need axles. I cant believe that nobody in the aftermarket makes shafts for an f100!!! Ive called EVERYWHERE! They all tell me its gonna be a custom order deal... Anyone know who may have a stock set?
Old 06-16-2012, 09:14 AM
What's the application for the 3rd member?
Old 06-16-2012, 09:28 AM
Quote:
??? im not sure what your asking... arent all 9" 3rd members the same reguardless of application?
Ford 9 inch Axles lm987 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 04-05-2015 10:38 AM
Ford 9 inch axles lm987 Clutch, Transmission, Differential, Axle & Transfer Case 0 04-02-2015 01:05 PM
What axles shafts can i use? 71Ranger97 1967 - 1972 F-100 & Larger F-Series Trucks 3 05-01-2014 09:27 AM
Help! 9" Ford axle shaft identification Dano78 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 04-17-2011 05:08 AM
Axle length dustybb01 Clutch, Transmission, Differential, Axle & Transfer Case 0 03-02-2010 07:53 PM
Tags
1966, 1977, 2wd, 62, axle, end, engine, f100, ford, gas, liter, lubricant, rear, standard
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
