Would airbag deployment not allow starting-diesel
I am looking at a parts truck. It is a '99 F450 with the 7.3 engine. The transfer case grenaded itself and in the process the front driveshaft took out the transmission case. The airbag also deployed. I would like to hear the truck run but it will not crank. I didnt have time or tools to check the obvious (battery voltage, solenoid and power to starter). Is there a safety like on a gas vehicle that the fuel pump is cut off when the airbag goes off?
zhicks16
38
12-18-2018 10:58 PM
