AC compressor will not come on. - Ford Truck Enthusiasts Forums
Old 06-13-2012, 05:32 PM
pecanflyboy pecanflyboy is offline
pecanflyboy is starting off with a positive reputation.
I've read a lot about this issue, but can't figure it out.
2003 F150 SuperCrew 5.4L, 4X2
Air Conditioning worked perfectly last night. Nice and cold.
This morning, no worky. AC compressor clutch is not engaging.
Here is what I've done, engine running, Max AC, clutch will not engage compressor:
  • Jumpered low pressure line switch
  • Jumpered high pressure line switch
  • Wiggled switch on compressor (could not get it to release, because I couldn't figure it out)
  • Clutch will turn by hand, engine running and not
  • Attempted to service low pressure port, but since the compressor was not running, the pressure at this port was 80+ PSI.
  • Checked AC clutch relay, AC Fuse, and AC diode
Because it ran so well just 12 hours ago, I feel like it something electrical.
Any ideas?
Thanks,
Jimmy
Old 06-18-2012, 03:10 PM
dad2bandm dad2bandm is offline
dad2bandm is starting off with a positive reputation.
Did you check the FAQ already...
I think this is likely your AC clutch gap, given what you described. Did you try tapping the clutch plate with the handle of screwdriver, to see if it engages then?
http://www.ford-trucks.com/forums/75...xpedition.html
Check this section:
"Symptom: No cooling. No engagement of compressor clutch"
Old 06-18-2012, 07:21 PM
Check this section:
As stated above my problem was the retaining bolt in the clutch. Thanks.
Old 06-18-2012, 10:40 PM
Good to hear...I just had to adjust mine a little while back. Same issue.
Stay cool. :-)
Old 10-31-2012, 02:39 AM
NewShockerGuy NewShockerGuy is offline
NewShockerGuy is starting off with a positive reputation.
My ac completely just stopped working out of the blue as well.
What do you mean the ac bolt? I'm looking at the av and checked all relay, fuses..etc. The compressor isn't engaging at all...but I can turn it by hand it's not seized our anything like that....
Thanks
Nigel
Old 11-04-2012, 07:11 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
Welcome to FTE, Nigel!
He was referring to the clutch gap. You adjust the gap by removing the center bolt in the clutch plate.
Checking and setting the clutch gap is outlined in the sticky at the top of the Forum.
Also, it's preferable to start a new thread about your issue instead of resurrecting an old thread. Just FYI.
Old 11-05-2012, 01:33 PM
Thanks for the reply I will have to check out the sticky now!
Normally I'd start a new thread but figured searching is best so it doesn't clutter the board up with the same questions being asked over and over..
Thanks,
-Nigel
2001 Explorer AC Problem/Question scrnchr Cooling, Heating, Ventilation & A/C 0 09-02-2014 12:05 AM
Need ac trouble shooting help 94 f150 jllaco 1987 - 1996 F150 & Larger F-Series Trucks 18 05-30-2013 12:57 PM
Need AC trouble shooting help 94 F150 jllaco Ford Inline Six, 200, 250, 4.9L / 300 7 05-25-2013 12:27 AM
Testing AC compressor TheKirbyMan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 09-18-2010 11:01 PM
Voltage at A/C compressor - no clutch engagement? tobyw 1987 - 1996 F150 & Larger F-Series Trucks 10 05-30-2007 01:56 PM
Tags
08, 2003, 390, ac, compressor, duty, f250, ford, forum, power, ranger, spin, super, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
