Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 06-13-2012, 05:33 AM
Spktyr Spktyr is offline
1995 Ford F-350
Spktyr is gaining momentum as a positive member of FTE.
Fuel Filter and Fuel Pressure Regulator
Couple questions about these things. I am going to be rebuilding a spare fuel bowl with a dieselorings kit; it occurs to me that this would be a good time to change out the fuel filter. The archives seem to be a little confused on this point - which filter is best, and is the Motorcraft still acceptable?
Also, is the fuel pressure regulator mounted to the bowl the same for 94.5-97 and only the stuff connected to the FPR is different, or is the FPR itself different?
__________________
1995 F-350 XLT 4x4: PowerStroke 7.3, E4OD, Crew Cab, Long Bed, SRW
  #2 (permalink)
Old 06-13-2012, 06:05 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
1996 Ford F-350
DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.
The Motorcraft filter (it is actually made by Racor) is a good one. In fact Riffraff Diesel is running a special right now where you buy two filters (cheaper than I have found them for the OEM filter) and you get a free coffee mug! There isn't an offer code or anything, but it is in their flier this month. The deal is supposed to be good through the end of the month.
Here is a link to the filter on their site.
Riffraff Diesel: OEM 'OBS' Fuel Filter
Mmmm, coffee!
Click the image to open in full size.
As far as the FPR goes, they are different, and in fact there are a couple of subtle differences in the fuel bowls between the 94.5/95 and 96/97 bowls. Mainly the location of some sensors. You may have to wrangle the wiring harness around to make everything reach, but either one will swap in there and work just fine.
Now I need to go get another cup of 'jo.
__________________
--Nate "Just a redneck geek"
1996 F-350 7.3L PSD, 4x4, CCLB SRW, 3.55's, E4OD, EBPV Delete, 3" DP, Stock Tailpipe and Muffler, Riffraff 6637 Intake, 400,000 miles and counting.
If it isn't under warranty, I'll fix it myself.
  #3 (permalink)
Old 06-13-2012, 07:05 AM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn is a splendid one to beholdTalyn is a splendid one to beholdTalyn is a splendid one to beholdTalyn is a splendid one to beholdTalyn is a splendid one to beholdTalyn is a splendid one to beholdTalyn is a splendid one to beholdTalyn is a splendid one to behold
94-95 is diff from 96-97 on the FPR.
I like the 94-95 system better myself.
__________________
Talyn (AKA: der Schafen Führer)
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, 5 SPD M/T Z/F S5-420, Rosewood 160cc Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic, 140V IDM, T-500, 285/75/16 Cooper Discoverer ATR. Steyr C9-A1.
You can get more with a kind word and a 2x4 than you can with just a kind word.
  #4 (permalink)
Old 06-13-2012, 07:17 AM
1995 Ford F-350
I plan on doing the fuel bowl overhaul this weekend, so there's not really time for me to order from Riffraff (sadly) and get it in time (without paying an exorbitant amount of money to a shipping outfit.)
My truck has over 312,000 miles - should I consider just replacing the fuel pressure regulator outright, or are they rebuildable? I have the o-rings and hoses from dieselorings - is there anything else I should consider replacing at this age and mileage on the fuel bowl while I have it out?
__________________
  #5 (permalink)
Old 06-13-2012, 07:24 AM
Talyn's Avatar
1994 Ford F-250
They dont really go bad, the spring gets a little weak though.
Midnight Mods: 7.3 PSD Fuel Mod
You can always adjust the spring to get it back into spec.
__________________
  #6 (permalink)
Old 06-13-2012, 08:08 AM
1995 Ford F-350
Is the spring available separately?
__________________
  #7 (permalink)
Old 06-13-2012, 08:15 AM
Talyn's Avatar
1994 Ford F-250
I think you can get them.
They dont really go bad.
Shimming them is a very effective way of adjusting, or you can stretch the spring a bit to adjust the fuel pressure as well.
Buying a new spring will not essentially give you the correct fuel pressure out of the box.
__________________
  #8 (permalink)
Old 06-13-2012, 08:31 AM
1996 Ford F-350
Shim it or build the adjustable type FPR. Here is the write-up went for the adjustable shim, and for the standard BB trick.
TikiWiki : Shim Your Fuel Pressure Regulator 94-97
__________________
Tags
200, 73l, f350, fuel, pressure, regulator, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
