Trying to find match for this Ford wheel
Looking for leads of people old enough to have knowledge of 40's-60's Ford dump truck wheels, duals.
I have a pic of the wheel I am looking for but not able to attach here.
The only description I was supplied with is not very helpful I'm afraid.
This wheel is Ford 17" 8 lug, 7.00-17 6 bias ply tire size.
Supposedly a 1960's era "widow maker" inside dump ford truck
The hubcap pops over the raised rib...no 3 or 4 nibs welded that hold the cap on
We had dumps...65 and newer and this doesn't look of this vintage.
I've learned to "never say never", but I don't know of anything that matches your description. An 8 lug dually would have first been found after 1966, but would not have been a 17", and would not use a hub cap. So I'm scratching my head. If you want to send me the picture I'll post it and see what we can make of it. Email is stu_sandymcmillan at sbcglobal dot net. Stu
on
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
Originally Posted by 47 Panel Guy
Ford 17" 8 lug, 7.00-17 6 ply bias ply* tire size / 1960's "widow maker" / Hubcaps pop over raised ribs.
7RY-1007 .. 17" x 5.5" Wheel-Use with Single Rear Wheels / 8 lug, 6.50" bolt circle / Marked: 49380 / Use with 7.00 & 7.50 17" bias ply tires / Use with "innie" hubcaps.
7RY-1099 .. Side Ring.
Applications: 1948/52 F2/F3 / Optional: 1953/66 F250 2WD & 1959/66 F250 4WD.
Innie: So called because the hubcap snaps onto tabs located on the inside of the wheels center section.
FoMoCo didn't offer front hubcaps for 4WD's until 1967, and these are "outies." Snap over tabs located on the outside of the wheels center section.
* FoMoCo didn't offer radial tires for trucks until the 1970's and then only as an option.
Radials invented by Michelin, first vehicle to have them as standard equipment: 1955 FWD Citroen 1D19. Citroen owned by Michelin back then.
First US vehicle to have radials as standard equipment: 1966 FWD Oldsmobile Toronado.
Joe,
Your knowledge / talents are amazing...I'm humbled.
Now knowing what these are will enable me to move forward with completing this phase of project...and get body/paint complete.
I have a 1947 Ford Panel Truck that I have set on 1997 E-350 dually, rolling chassis-with 7.3 D.
Having cut the frame to narrow at the back of the block left me with a wider stance in the front to deal with. I have replaced the dually hubs with the 1 ton inline hubs but yet need about 3" more offset to pull tires back under the fender. Having found this mystery wheel to fit perfect on the truck I will be using the center only and replacing the ring with offset to gain the 3" and eliminate the existing wheel strike on fenders when turning and or compression of coil on turn. I wanted the nostalgic look for my vintage and am not a fan of alloy wheels ( which would have been ez to make)
I'm not a fan of being online much...cuts down on my getting hands-on with work getting done but would be glad to talk on telephone.
Either way...thanks for your help, I do greatly appreciate.
Randall
707 495-2580
Randall
707 495-2580
Stu,
A picture is worth a million words.
This is exact match...amazing.
You guys are great!
I have went from not having a clue to knowing the history of the wheel as Joe and you have provided.
Armed with this information...I know where I can probably find these wheels that I wouldn't have even thought of before now. My info-telephone is listed on the reply sent to Joe...would be enjoyable to talk.
Thanks again,
Randall
You guys are great!
Thanks again,
Randall
leawq2
38
12-22-2023 12:25 PM
mlandrum51F1
01-24-2016 10:09 AM
roc.r1
02-07-2004 09:56 AM
