92 F-250 Dual Battery
Steve
You might want to look into using a deep discharge batt like they use in RVs. They're designed to take more charge/discharge cycles. (They also put out less current for their size, but that shouldn't be a problem).
I presume that the isolaters RV_tech refers to keep the load on the aux battery while the engine is off. I wonder if they do anything to moderate the current so that the generator isn't hit as hard with the load from the aux batt.
good luck,
hj
good luck,
hj
good luck,
hj
good luck,
hj
Steve
The stock dual battery setup mounted the batteries right next to each other, and ran a heavy cable from post to post. A battery isolator or Automatic Charging Relay (the modern version) gives preferential charging to the primary bank over the secondary bank, so manual switching is not required for charging, as well as improving charge quality by putting full voltage to each bank individually. This is most important with Dual Purpose and Deep Cycle batteries. Not really/necessarily required in the automotive world.
-Mike
-Mike
Just install a 3G alt and a group 65 quality Battery and don't look back you'll be just fine !!! Dave
Optimistic Paranoid
Electrical Systems/Wiring
10-20-2015 07:36 PM
bneafus
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-25-2007 10:02 PM
