Rode hard and put away wet !
As is typical with my projects they start out simple and get complicated. It all started off with a brake shoe keeper that came loose on a rough road. Of course I had to pull the drum on the right side. Then naturally I wanted to check the left, sure enough one of the keepers was so loose that it fell off when I moved one of the shoes. Then finding the keeper for an F-2 was fun. Nobody stocks #2296 but I took a chance and ordered the similar car part 51A-2125 from Mac's. After I received it I think that it looks the same.
Then of course things were very dirty so brake clean fixed that. Lots of rust on the backing plates so I took them off so I could clean them up and paint them. I knew the left tie rod end had too much play so I removed it from the suspension. But while I was doing that I noticed that the sector shaft on the steering gear was moving up and down about 1/4". No wonder the truck had the "death wobble" going down the road.
Then as I rotated the suspension through out its travel I noticed that the steering box felt like it had rocks in it. I guess it is time to move up to power steering. Of course this means a new steering column too.
Finally today I tried to take the bad tie rod end off the tie rod. The clamp nut, as you can see from the picture below, had corroded so badly that it was almost non-existent. Time to cut the bolt. But first I thought that since the left was corroded I should check the right end. That is when I discovered that the tie rod was seriously bent. Then the right end would not come loose from the suspension. Time for a trip to the local NAPA store for a pickle fork.
Does any of this sound familiar to anyone or am I the only one that has this kind of luck? Aren't old trucks fun? If anyone hears of a bank being robbed in Michigan it wasn't me.
Thanks guys. I'm glad that it is just not me. Actually I have been so involved in correcting or coming to terms with the things that various POs have done that I am now just getting into the things that Mother Nature and wear & tear have done.
These are such great looking trucks . . . they need to be fun to drive.
The PO did some strange things on mine too. He put a Chevy drive train - 350/TH350. The motor mount was a homemade metal bar bolted directly to the frame on both sides, curving under and had plates bolted directly to the block. No rubber mounts at all. The transmission was the same but the bar he made was just sitting on the frame - no bolts and no welds. Plus about a gallon of bondo and a yard of fiberglass on the front fenders. When I got all of that off, I found that the fenders are pretty much toast. There was a ton of rot that he just covered with fiberglass and then bondo. He actually built it up over 1/2" thick where the two pieces of the fenders meet. It had a B&M shifter for a powerglide (2 speed) with two screws in the inspection cover and a cable. It wiggled around so much I don't know how he ever shifted it. And a dozen other rigs all over the truck. Took me quite a while to even figure out what some of it was. All his BS is gone now, but I still have a ways to go to be driving. I have had the truck one year this week.
AMG-SM
61
08-14-2017 03:00 PM
lonestaraggie
07-23-2008 10:37 PM
