Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 06-12-2012, 08:54 PM
gtilton.as gtilton.as is offline
1960 Ford F-350
gtilton.as is starting off with a positive reputation.
1960 F350 with a 292. Engine HP
Plate in truck says 146 HP but everything else I read says 185hp for a 1960 292. I know it doesn't really matter but I am curios.
What are your thoughts.
  #2 (permalink)
Old 06-12-2012, 09:15 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Garage is empty, add now
theodore/teddy is starting off with a positive reputation.
Whats the fourth digit in your serial number.
According to my book 1960 292 2v==146hp
The only engines showing 180hp +- was the 332 and up
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #3 (permalink)
Old 06-12-2012, 09:23 PM
1960 Ford F-350
The 4th digit is a C.
  #4 (permalink)
Old 06-12-2012, 09:33 PM
Engine code C = 292 2v 146hp @ 3800 rpm
That information is right out of Ford parts and accessories manual (on CD) you can pick them up on Ebay for about 20.00
Good luck in your quest
__________________
1959 F250 4x4
Wally
  #5 (permalink)
Old 06-12-2012, 09:42 PM
1960 Ford F-350
Yes i have that information. But i also have Eickman's YBlock book and it shows the 1960 292 as 185. Some other online sources show the 185 for 1960 trucks.
  #6 (permalink)
Old 06-13-2012, 12:23 PM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
The 185 might be for cars.
For the trucks, there are two ratings for each engine (three if you include "taxable horsepower").
For the 1960 trucks, the 292 MD (2 barrel carb), the truck operator's manual lists 172 hp @ 4000 rpm. This is "gross" hp. The number on the plate on the glovebox door (146 hp @ 3800 rpm) is a net hp, or what is available when the engine is installed in the truck with all accessories (air filter, generator, muffler, and so on). And the horsepower does vary with engine speed. The max torque of 270 lb-ft @2600 rpm gives 134 hp
Just for grins, the taxable (SAE) hp is listed as 44.60. Not related to power at all, but related to bore diameter and number of cylinders.
  #7 (permalink)
Old 06-13-2012, 02:41 PM
1960 Ford F-350
Thanks 3414, that actually clears the numbers up quite a bit. Now that my curiosity is settled, I can get back to the real task at hand which is unloading that dump body so I can put the truck into the garage and fix the brakes and sheet metal.
Tags
1960, 1961, 292, 350, codes, engine, ford, horsepower, hp, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
