02 F150 Aux Audio Input
My wife has a 02 F150 Lariat that does not have an Aux Audio input in the radio/CD, so I'm hoping that someone can help me, did Ford make a radio/CD that will plug and play in the 02 that has the Aux Audio, if so what years? If not is there a way to add the Aux Audio?
Yes, The CD-DJ will allow you add in an outside interface or external changer. I am not sure if it was available on the single disc radio, but some 2002 6-disc and pretty much all of the 03-04 6 disc changers should have it. There is a test to do to see if the CD-DJ feature is available but I never saw a sticker displaying it.
A quick way to determine if your radio supports the CD / disc jockey functions necessary for the PIE adaptors to work is to run a diagnostic self test
1. Turn the radio on and place it in AM/FM mode
2. Simultaneously press the audio unit preset buttons 3 and 6 to enter speaker walk around test mode.
3. Press Preset button 1 to start the self test
4. After the self test is done use the “DISC TUNE” right button to display the codes
5. To exit the self-diagnostic mode, turn the ignition switch off or the audio unit off.
If it throws a “U2003 CDDJ" code (you may also see “U2008 Phone” and “U2005 RICP), the software is looking for an external CD / Disc Jockey unit, and
not finding it. This means your unit has a good chance of working with one of the PIE adaptors.
cmorningstar01
2004 - 2008 F150
06-02-2015 05:41 AM
