93 - clutch release bearing install - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-12-2012, 06:24 PM
93Ranger 93Ranger is offline
93Ranger is starting off with a positive reputation.
93 Ranger, 4.0 liter, 4WD
Putting in a new clutch and clutch release bearing, and am wondering if I need to put the retaining ring in that came with the new clutch release bearing? When I took off the old release bearing, a ring did come off from somewhere, but I did not see where it was because it was so dirty.
The reason I ask is because my Haynes manual did not even mention a ring, so I was surprised to see one come off. And my manual does not say to reinstall the ring when installing the release bearing. I did get a newer Haynes manual at the library and looked through a bunch of Chilton, etc manuals. The newer Haynes manual says to remove the retaining ring on 97 and newer models, but says nothing about putting it back in when reinstalling. So, I am not certain if I need to put a new retaining ring in with the new release bearing.
THANKS
Old 06-12-2012, 06:51 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
I hope you're replacing the slave while you're in there.
Old 06-12-2012, 09:23 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
X2... replace the entire unit not just the bearing. Just don't purchase the cheapest slave you can find.
Beyond that the retaining ring is usually a spiral clip and attaches on the groove on the end of the slave snout
Josh
Old 06-13-2012, 08:24 AM
Does a new slave cylinder come with the throw out bearing? I am going down and see what I can get.
How much should a good slave unit cost?
Old 06-13-2012, 09:56 AM
Bullitt390's Avatar
They can be bought either way, with or without the bearing.
I think Perfection at Advance Auto us a good unit or the rebrand unit at NAPA. Can't beat the Motorcraft unit, but it's well over $100.
Josh
Old 06-13-2012, 12:04 PM
Thanks. I had to run an errand this morning so I stopped at the nearest parts store and they had a slave that came with the bearing for $50. We do have NAPA in town, but I fear to see what their prices are. I know they have good quality parts, but the economy has not been kind to me. Is Advance Auto an online retailer because I have never seen them here in the northwest?
Since I already have the bearing I got with my clutch kit maybe I can find a slave unit without it for a little cheaper. Or am I just asking for trouble?
When you replace a slave does that make for more of a headache to bleed the system?
Old 06-13-2012, 12:52 PM
Bullitt390's Avatar
It isn't too bad as long as you don't let the reservoir run dry while bleeding the slave.
You just gravity bleed...
Advance auto is also Western Auto in some spots. I think napa wants about $10-20 more for their slave over Advance even though they are both made by Perfection.
The suggestion to replace the entire slave is more a preventative measure an since you have everything apart it is a "might as well" type of thing.
If the slave you have now looks in great condition you could by all means continue using it.
Josh
Old 06-13-2012, 02:44 PM
Thanks, I will probably just replace the whole slave. It will give me peace of mind when I am 20 miles from the nearest highway.
I am going to pull the old slave and look at it, but I would have no idea how to tell whether it is still any good. Then I am going to get serious about shopping for a new slave unit.
New clutch issues Paul M. 1987 - 1996 F150 & Larger F-Series Trucks 23 01-17-2017 09:26 PM
Steering column wobble repair. akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 07-13-2012 06:25 PM
problem installing Warn manual hubs meb9796 1987 - 1996 F150 & Larger F-Series Trucks 5 02-20-2012 02:38 PM
bronco wont move, new clutch |WYG|SS 1978 - 1996 Big Bronco 5 02-07-2012 04:05 PM
Clutch Master Cyl hose to Slave cyl jtannenba 1997 - 2003 F150 5 07-19-2007 06:12 PM
Tags
1986, 40, bearing, clutch, colorado, f150, ford, high, internet, manual, powered, ranger, speed, throwout, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
