Critterf1 is correct. If you had an ABS problem, that light should come on. I ruptured a rear brake line a few years ago, which caused both lights to come on. The red light with the word BRAKE showing indicates that you have low fluid or, your e-brake is on.
The part about having to lift up on the parking brake pedal to turn off the light should be a clue as to the problem...
Nothing about low fluid.
Nothing about ruptured lines.
Nothing about ABS.
Hmmmm..... just what could it be?
Josh
It would be a clue - if it were posted by the OP - which it wasn't...
Originally Posted by Dan Robertson
I have to pull up on the e-brake peddle with my toe while holding out on the release to get the peddle to come up enough to get the light to go out.
Maybe the OP (awright48) can try this trick and see if he can get the light to go out. I have to do this on my '04 but my brakes are in pretty bad shape lol...
wow...well it was a pin hole leak, that I did not see at first, which then got bigger and finally burst. I had to replace my right front brake line...if I wasn't busy I would have saved $290. Oh well. thanks for all the help!
