Need help identifying engine parts
I am working on a 1958 F100 with a Y-block 272 motor. I am just starting on my project and noticed things are a little different then todays motors and I have a lot to learn with this project. Anyways I am trying to figure out what these three items on my motor are. If any one could help it would be greatly appreciated.
Larger Image Here
1.) I am assuming this is a fuel pump or filter
2.) I am not sure if this is an oil filter of some sort.
3.) ?
Larger Image Here
3.) ?
Last edited by eric_1982; 06-12-2012 at 05:47 PM. Reason: Supply Larger Image Link
Eric here you go.
[IMG]Welcome to FTE
Why mess (in more ways than one) with the old by-pass cannister oil filter when you can install a gen-u-ine Ford full flow Spin-On oil filter using its adapter kit instead?
While this kit was introduced in 1957, it was an option on some 1957/64's. I just looked this same puppy up for a member of the 1961/66 forum.
B7A-6882-A .. Spin-On Oil Filter Adapter Kit - Use with Motorcraft FL-1A Oil Filter (most common oil filter used 1957/96) / Obsolete / 1,537 (!!) available NOS.
Passenger Car/Truck applications: 1952/53 215 I-6 / 1954/64 239/256/272/292/312 Y blocks / 1954/64 223 I-6.
Some sources that have the kit =
The LINCOLN-MERCURY OLD PARTS STORE in Clearwater FL has 5 = 727-445-7551.
GREEN SALES CO. in Cincinnati OH has 8 = 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has 10 = 888-77-0418.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1,475 (!) = 800-476-9653.
EAA-6838-A .. Cartridge Oil Filter Gasket-Between Cannister & Mounting Plate / Obsolete
Passenger Car/Truck applications: 1952/53 215 I-6 / 1954/64 223 I-6 / 1954/64 Y blocks.
GREEN SALES has 9.
CARPENTER has 20.
DICKERSON MOTOR CO. in York SC has 32 = 803-684-4225.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2011 F150 5.0L 2WD Lariat Super Crew.[/IMG]
[IMG]Welcome to FTE
GREEN SALES has 9.
CARPENTER has 20.
__________________
1958 58 FORD TRUCK SHOP MANUAL - REPRINT - ALL MODELS | eBay
Or this one!
FORD 1958 Pick Up & Heavy Duty Truck Shop Manual CD '58 | eBay
But truthfully, I would rather have this one!
1958 FORD TRUCK SERVICE SHOP MANUAL REPAIR BOOK 58 | eBay
Christopher2
05-17-2005 07:24 PM
