Highboy Gas Tank - Ford Truck Enthusiasts Forums
Highboy Gas Tank
Old 06-11-2012, 09:10 PM
PhilMac's Avatar
PhilMac PhilMac is offline
PhilMac is starting off with a positive reputation.
Highboy Gas Tank
Hey,
I've got a '77 F-250 Highboy that has been sitting for about 10 years. I have finally started the resto process on it. I have rebuilt the 460 in it and went through the brake and steering system and also replaced wheel bearings and u-joints. All I had left before my first drive was to clean the fuel tank and reinstall it. So much for that, it had a 1/2 rust hole in the bottom. I have seen that the most popular replacement is a '84 Bronco II tank to go in the rear. I love this idea but I have a few questions.
1. While this tank does not seem to be overly expensive I am on a budget and trying to keep cost down. My local pull-a-part junkyard has a '87 & '88 Bronco II. Will either of these tanks work?
2. I understand that Highboys never came with a rear tank from the factory. My bed has a fuel door behind the rear tire on the fender. I'm not sure if the truck has been wrecked in the past and the bed replaced from a donor truck or what. Can I use the fuel door with a Bronco II tank? I don't want to have 3 fuel filler holes in the truck.
3. Does the Bronco II tank tuck up in the frame rails enough so it won't get caught on anything while offroading?
4. Do people make their own tank straps when doing this install?
Thanks for any help!!
-PhilMac
Old 06-11-2012, 10:13 PM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
I have a in-cab tank from a 77 f250 available in NJ if you are interested.....
Old 06-11-2012, 10:18 PM
PhilMac's Avatar
Thanks for the offer. Since I am going to have to get a new tank its a good opportunity for me to relocate it. I also live in Alabama so by the time I pay to have it shipped it may be worth it to buy new. Thanks again.
Old 06-11-2012, 10:30 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
The in cab tank is still available through Dennis Carpenter or Blue Oval Truck Parts for around 200 bucks.
Old 06-11-2012, 10:46 PM
$50 + shipping if you change your mind
Old 06-11-2012, 11:22 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
not familiar with the bronco II tank, but yeah, the in cab trucks did NOT have a fuel door, so the one you have should work. not sure what plumbing will be necessary to get fuel from door to tank though. I knew someone who used a plastic tank out of a newer F350 chassis cab, fit in the narrow frame like it was made for it....
Old 06-12-2012, 04:19 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by montana_highboy View Post
The in cab tank has been reproduced by Blue Oval Truck Parts for around 200 bucks.
But, this is not the same in cab tank used 1973/77. The tank you're referring to is this: DOTZ-9002-A (replaced C1TZ-9002-K) .. 19 1/2 gallon capacity / Obsolete-Reproduced.
FoMoCo service part replacement: 1961/66 F100/1100 / 1963/69 N/NT/T500/1000 / 1967/69 F800/1000 (use the earlier cab) / 1967/69 F100/750.
Factory installed: 1970/72 F100/750 except 1970/72 F100/250's with Evap/Em.
1973/77 In-Cab Fuel Tanks
D3TZ-9002-F .. In-Cab Fuel Tank-Use without Evap/Em / Obsolete
D3TZ-9002-G .. In-Cab Fuel Tank-Use with Evap/Em / Obsolete
Old 06-13-2012, 01:11 PM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
The Bronco II tanks will fit between the frame rails...but unless you modify frame cross member (I won't do that)...it sits too far forward and in 4 wheeling situations axle would hit the tank....I've used a 2wd rear tank...turned sideways and made custom straps and mounts and it worked great!!!
Old 06-13-2012, 01:51 PM
lasthighboy's Avatar
lasthighboy lasthighboy is offline
lasthighboy is starting off with a positive reputation.
i wrote an article on here about using a ranger tank in the rear of a highboy. Wanted it to show up as a sticky because there have been a lot of people asking about it but i guess the moderators didnt approve. I did it in a 77 highboy that had the fuel door in the bed, but it was bolted shut. i removed that door and used a fuel filler setup from a 73 ltd. moved the small angle iron crossmemer forward to attach the front of the straps to and welded some hardware store hinges onto the rear of the ranger straps and bolted them to the rear crossmember to hang the tank.
Old 06-13-2012, 10:14 PM
PhilMac's Avatar
lasthighboy, what year and configuration was the ranger that you got the tank out of? I would imagine it would be easier to find a tank out of a ranger just because of how many there are.
Thanks
Old 06-29-2012, 01:39 AM
it was out of an early 80s ranger. 83 or 85 probably. rear tank. tried a front tank that ran along the framerail but the left rear shock was in the was if i remember correctly.
Old 06-29-2012, 01:52 AM
Strigoi's Avatar
Strigoi Strigoi is offline
Strigoi is starting off with a positive reputation.
Quote:
The fuel door on the bed is from the factory. Mine has it as well even though there is no rear tank. When I got it smogged after buying it I had to explain it to the smog guys since they were trying to pull it open.
You can just barely see it in my sig pic.
Old 05-09-2014, 06:18 PM
71fordf2504x4 71fordf2504x4 is offline
71fordf2504x4 is starting off with a positive reputation.
i am trying to make a 74 f250 2wd rear tank fit in a 71 f250 4x4...
currently we moved a small cross member forward towards the rear axle and the stout rear cross member as far back as possible. we
added a stout v-5 ford hitch that mounts to the bottom of frame rails
4 massive bolts on each side
turned the tank so the filler goes out the back just under the tailgate
straps above and below that came w/ the 74 tank
the tank is tapered (left side deep to right side shallow)
if i get the front of the tank lower than the filler so the tank can actually be filled to capacity and not sit in the hose causing a leak
should this work?
should the 74 sending unit work w/ my 71 fuel gauge?
thank you!
This must be the easiest highboy rear tank option F350moneypit 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-17-2016 02:47 PM
Fuel tank setup on 75 F250? d_gant 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-21-2015 04:22 PM
fuel tank moved to rear have fuel pump question jwilly53 1961 - 1966 F-100 & Larger F-Series Trucks 1 09-01-2015 07:39 PM
Question for those who have relocated their highboy fuel tank to the frame FordIowan 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-18-2015 01:39 PM
fuel tank/bed questions AbusedAmericanRust 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-30-2014 06:38 AM
Tags
59, 88, bed, bronco, cab, crew, door, ford, fuel, gas, highboy, install, oval, replacement, size, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
