Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-11-2012, 02:00 PM
moosey78 moosey78 is offline
1999 Ford E-Series Van
moosey78 is starting off with a positive reputation.
jesse yarbrough moosey78
2.3 crank wont turn.
I changed the crank on a 78 2.3 to an 89 2.3 crank, replaced all the bearings and the crank won't turn with the mains tight, loosen the mains and it turns. Factory crank with standard bearings. What am I doing wrong?
  #2 (permalink)
Old 06-12-2012, 06:43 AM
critterf1's Avatar
critterf1 critterf1 is offline
Garage is empty, add now
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Wrong bearings?
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 06-12-2012, 03:09 PM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
Quote:
assuming you have the correct bearings (use plastiguage to verify)
Loosen the the mains, apply lube to the bearings & crank, with the bearings only snug, turn the crank by hand (with a wrench), tighten a little more, turn again......yes your arm will get tired but this is how it is done, assuming you have the correct bearing and bolt torque settings......
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #4 (permalink)
Old 07-28-2012, 02:57 AM
Got it fixed, rod had a shoulder and would get hung up, ground it off and it spins
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
