blue spring upgrade question
You will need that adaptor to go from 1/8" to metric with O-ring
For the life of me I can't recall the size of the silly thing.
If you search you will find a post that will tell you.
OR some nice person will post it here for you.
One other thing DON"T screw it in too tight you could crack the housing.
Just enough to seal it because it does have an O-ring
Sean
Sean
Actually, this is from the Tech Folder:
Recommended readings - Temperatures and Pressures
STOCK READINGS
Normal Severe Service Alarm
Tranny Temp 150 - 195 195 - 200 220
Coolant Temp 190 - 200 200 - 215 215+
Fuel Press 60 - 50 50 - 45 45
EGT - pre Turbo 650 - 1200 1200 - 1250 1300
EGT - post Turbo 700 900 1000
Boost 0 - 26 27 - 28 28
Oil Temp 200 - 215 215 - 230 230+
READINGS WITH TUNERS
Tranny Temp 150 - 195 195 - 220 230
Coolant Temp 190 - 215 215 - 220 220+
EGT - pre Turbo 650 - 1200 1200 - 1300 1300
Boost 0 - 26 27 - 30 30+
Oil Temp 200 - 230 230 - 235 235+
STOCK READINGS
savagehenry
26
03-04-2023 08:19 PM
RideDiesel88
10-15-2012 12:15 PM
