dipstick tube leak help please
one bad weekend for me fellas. finished relocating my fuel pump and remote filters, fired truck up and oil was running out of dipstick tube, looked and found the little o-ring was cut and sticking out, pulled it and replaced o-ring with just a standard o-ring, this stopped the leak momentarily. later on I looked to see if truck was leaking, and found oil was now spraying on the frame and fender well of the passenger side, going so far as to hit the shock. is this just due to the o-ring i put on there being the wrong one and allowing the oil to pressurize? I have ordered the right o-ring.
From normal blow-by the internal of the block is pressurized to some extent. The CCV should ventilate the gases for the most part. When you take off your oil fill cap, do you get a bunch of blow-by or normal amounts? You may want to check your CCV set-up.
The o-ring being right or wrong won't cause pressure to build that isn't already there. It may allow it to leak though. Are you sure that is the leak point?
on
I found the level indicator fitting in the pan loose on my truck and tightened the large nut. It has been "leak-free" since.
I haven't checked the ccv yet, or the fill cap for excess blow by, will have to do that after work today. this sucks, all I wanted was to be done with the regulated return and see what she does, but instead I have to fix more stuff.... that's just my luck. Murphy's law seems to always fall in my lap.
Roland, we're typing at the same time. I dont take it as you are implying it would cause the problem.
Shiny62
07-18-2005 08:07 PM
