Why you should change/refresh your air filter...
I purchase my 2005 Excursion 6.0L about 2 weeks ago and have been doing some PM as well as basic upgrades. This weekend was to inspect and recondition the aFe air filter. What I found was not cool.
Pic 1: Note the trash all over my garage floor that fell out when I simply disassembled the filter from the housing.
Pic 2: The housing had surface rust and peeling paing all over. I couldn't put it back in the truck like that.
Pic 3: Sanded housing, removed surface rust and peeling paint.
Pic 4: Primed/painted housing. I used Dupli-Color Rust fix as a primer (it claims to stop the rust oxidation) and then a Dupli-Color, heat-tolerant engine black. It won't win any custom paint job awards, but no more rust and peeling paint.
Pic 5: Reconditioned aFe air filter with their cleaner and oil.
Pic 6: Reinstalled and looking good (at least compared to how it came out).
Next up: Blue Spring upgrade.
cheezit.
I agree with you so much.
I had a K&N in a Explorer
I owned so may years ago and got tired of having to clean the
Mass Air Flow sensor, and throttle plate that I removed the thing
Thinking that if I was seeing this what else was getting past.
The Powershop in Enumclaw had given me a list of things to upgrade
they said use the Banks unit because the back side seal on the Ford one
de-formes. I thought at the time I would stick with the Ford one because
I had already been doing research on the 6.0L
Hell if the Ford one works and gets the job done. Why should I change it?
I am not a if it don't go chrome it type of guy
Sean
Sean
I bought the X with the aFe filter but have read about sticking with OEM. I've had a P0299 CEL (Over/Under boost) while towing my 8,000# travel trailer. Not good omens... Thanks guys.
Will you please confirm OEM part numbers and comment on which of the following to use? Change intervals?
Ford 4C3Z-9601-AA (blue media, I think)
Donaldson P603577 (white media)
Donadlson P603577-EA (blue media)
Taking your advice. Thanks.
on
Thipdar
04-07-2018 12:47 PM
clintonvillian
17
01-22-2018 04:00 AM
Harrier
07-31-2017 08:26 AM
52 Merc
32
07-20-2015 07:33 PM
