Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-11-2012, 07:20 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
Exhaust thermostat control valve
Had some time to work on the fleet back on Saturday. Finally got around to replacing ehhaust manifold gaskets and rocker cover gaskets on the green F600.
Along with the exhaust manifold gaskets I was going to replace the gutted and cracked exhaust thermostat control valve, but my replacement one interfered with the rocker cover. And I thought I had the correct one on hand.
Has anyone else run into this? there are two pins on the side opposite the counterweight and bimetal coil, and a spring between the two pins. On my replacement the pins hit the rocker cover. On the other two F600s the orientation of the valve shaft is different so there is no interference.
Looked up the part number and it is C0TE 9A427-A, Now I start the search.
Also, anyone know where to start looking for a shifter **** for a Clark 250V direct 5 speed? Need to replace the one on the red F600, as the old one started to fall apart in my hand.
Tags
1973, exaust, f100, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
