Need bed bolts....u know where to find them? - Ford Truck Enthusiasts Forums
Old 06-11-2012, 12:13 AM
awcforever's Avatar
awcforever awcforever is offline
awcforever is starting off with a positive reputation.
I have a 99 F150 short bed......I need all 6 bolts and the little slide nut/fastners that go over the frame.
I found a set on ebay, but I can't justify paying $100 for bolts.....crazy
I had to drill all of mine out after I broke 3 star keys. If I can't find them cheap I am just going to attempt to use some store bought grade 8's.
It would just be a whole lot easier with the original hardware to avoid having to get under there with wrench/ratchet.....
Thanks.
Old 06-11-2012, 06:16 AM
94powerstroke 94powerstroke is offline
94powerstroke is starting off with a positive reputation.
i dont know about the heritage style but on my 94 f350 when i installed my box i used stainless carriage bolts and big flat washers so they would clamp the box a nd not pull trough. if you want the actual original hardware youd have to go through the dealer or maybe Lmc reuck or Nationalparts depot depending where you live you can try crosscanadaautoparts.com thats what all the body and collision shops use to order panels and stuff.
Old 06-12-2012, 09:04 AM
awcforever's Avatar
Quote:
I called the dealer and they want $7 per nut, $26 per bolt and $5 per washer.......$228!!!!!!!!!!!!!!!!!!!!!!!!
I think I am hitting the salvage lot today. I assume that most of these places pull the beds for resale and I am hoping the speed nuts for the trucks are still attached to the frames.....thennnnn I can use whatever bolts I want....
Hopefully.
Old 06-12-2012, 09:14 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Call Tousley Ford.
Old 06-12-2012, 12:20 PM
coolguy1419's Avatar
coolguy1419 coolguy1419 is offline
coolguy1419 is starting off with a positive reputation.
I would just go to your local hardware store and get bolts, washers, an lock nuts. If you put on a body lift they give you normal bolts to use. It's a pain to have to wrench on them alittle but in the log run it is by far cheaper!!
Old 06-12-2012, 10:27 PM
Mickirig1 Mickirig1 is offline
Mickirig1 is starting off with a positive reputation.
I live in an old Industrail area. The "rust belt". We have fastener places that pretty much have anything you need when it comes to bolts/nuts/etc! Try one around you,know the sizes and what you want. The stuff is dirt cheap compared to a dealer. Grade 8 is not a problem. Fastenol comes to mind, you should have one or two in your state. My Nephew delived to your state as a truck driver.
Bed Bolts for SUPER DUTY!!! BlueBeauty 1999 to 2016 Super Duty 8 06-23-2016 05:55 PM
Leaf spring help HkyswiM 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 08-31-2013 08:29 PM
Bed bolts brian1080 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-15-2011 11:19 AM
Bed mounting Bolts swordman 1973 - 1979 F-100 & Larger F-Series Trucks 26 11-28-2010 04:50 PM
Bed Bolts dstig1 1999 to 2016 Super Duty 26 07-10-2009 11:51 PM
Tags
1978, 2002, 96, 97, bed, body, bolts, carriage, f150, f350, ford, screws, short, special, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
