2004 Explorer engine rattle - Ford Truck Enthusiasts Forums
Old 06-10-2012, 08:50 PM
scooter3 scooter3 is offline
scooter3 is starting off with a positive reputation.
Question 2004 Explorer engine rattle
I own a 2004 Explorer Eddie Bauer Edition with 182,000 on the clock that has developed a very annoying engine rattle. The rattle started just shortly after having some service done on the truck. I had the P/S, Brake, Transmission and Rear diff fluids replaced. I also had the A/C system evacuated and recharged along with replacing the A/C manifold line and rack and pinion. The noise is most noticeable at first start and goes away when driving. I took it to Ford and they said that the timing belt tensioners were bad so they were replaced, but the noise was still there. Then they replaced the serpentine belt tensioner and pulley, but again noise is still there. I refused to have Ford do any more work since I had already been charged almost $1500 for repairs and the problem was not fixed. They said the next thing would be the balance shaft or rebuild the engine. The truck runs fine, smooth and does not shake at idle. It just has this awful noise. I have tried other forums with no luck so I am hoping someone can help me identify this issue; here is a video of the noise. Any help would be great.
http://youtu.be/jOijGtqUVQY[/URL]<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old 06-21-2012, 07:03 AM
200 views and not one comment?
Old 06-21-2012, 09:48 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Get your self a mechanics stethoscope or a length of rubber hose, then use it to isolate the source of the noise..
Keep in mind that crystal ball diagnosis is not recommended.... Philip
Old 06-24-2012, 12:37 PM
Eddie D Eddie D is offline
Eddie D is starting off with a positive reputation.
04 Rattle...
Hi,
Are you sure it is not a loose heat shield rattling underneath your truck. I have an 04 sport trac that rattled like crazy at idle, drove me crazy. so I went under my truck and ripped it of. No more rattling...
Anyway, just my two cents, hope it helps.
Ed
That guy with dumb questions! FuzzFace2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 05-21-2016 09:53 PM
6.0L powerstroke overcharging Lugslap 1999 to 2016 Super Duty 3 01-25-2013 01:35 PM
Lack of power xoloski Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 05-29-2012 12:10 AM
What is my trim level? ABF PSD 1999 to 2016 Super Duty 11 02-09-2012 09:26 PM
2003 F350 6.0 Tranny. (What one do I have) Jnas860 Clutch, Transmission, Differential, Axle & Transfer Case 1 01-23-2011 06:54 PM
Tags
04, 2003, 2004, 2005, engine, explorer, ford, idle, making, noise, rattle, sport, start, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
