Replacing the rear window on a 2005 Explorer
Old 06-10-2012, 10:47 PM
Calhoon21's Avatar
Calhoon21
Calhoon21 is offline
Hello to All,
I'm new to the forum however I have always sworn by Ford Trucks but anyway on to the reason for this post.
My rear window was shattered this weekend and I am looking to replace the window. Problem is I cannot find any instructions on how to do so. Can anyone point me in the right direction or forward me some info on how to do so? Also if you have a link on where to purchase the glass that would be helpful as well. Thanks again!!!
Old 06-10-2012, 11:25 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,584 Likes on 1,292 Posts
Am I correct that your '05 (as my '98) is just glass back there?
If so, the new glass is simply fitted to the hinges and latch and away you go.
My hinges have worked loose both where they attach to the gate and the glass. I drilled one all the way through and used a nut and bolt. I am about to do the same on the glass side. Hinges from Ford are $50+ per side.
Check the actual hinge pins as well.
For glass, google "missouri auto glass" and you'll be days going through all the links. Or you can call your friendly Ford dealer.
You might find one in a junk yard, but time is money imo.....
Old 06-11-2012, 06:49 AM
shorod's Avatar
shorod
shorod is offline
Calhoon, are you referring to the side glass beside the third row seat, or the rear liftgate glass?
-Rod
Old 06-11-2012, 01:07 PM
Calhoon21's Avatar
Calhoon21
The rear liftgate glass. From what I'm seeing the glass is pretty expensive.
Everford
1983 - 2012 Ranger & B-Series
09-04-2017 09:09 PM
Sparksone42
04-30-2010 09:29 AM
pipman76
05-19-2008 05:39 PM
ghunt
02-25-2008 09:57 PM
VelocityDriver
09-19-2004 05:35 PM
Quick Reply: Replacing the rear window on a 2005 Explorer
