1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
f150 or f250 front hums for a go kart?
Old 06-11-2012, 06:56 PM
creativecars1's Avatar
creativecars1
creativecars1 is offline
Originally Posted by parkland
That also sounds like a fun project.
I've built a few in the past, and ended up being to big to nicely fit in a truck.
Thats a really cool idea with the transmission output shafts driving the front and rear.
I have looked into using 7.5 or 8.8 IRS rear ends out of tbird/cougars
and shortening up the axles for the proper width.
You could also use hydraulic motors on each wheel and let the motor power a big hydraulic pump for even more ground clearance.
Old 06-11-2012, 07:19 PM
creativecars1
Oh yeah, and if you have an unlimited budget you can put cv joints on the ends of these.. Speedway Engineering's Mini Stock Quick Change Rear Ends
and change gears to go highway speeds or pull houses down.
Old 06-11-2012, 10:53 PM
parkland's Avatar
parkland
parkland is offline
I had considered hydraulic motors and a pump, and found some that run a 700 rom max, which should have worked... but I imagine power would be less, and the thing would burn a ton of fuel at any speed.
The 5 sp car tranny and 60 h roller chain going in I bet is 85% effecient.
Hydraulics i bet are 40-50%.
drumdude
05-14-2012 04:17 PM
darrmann
11-13-2006 07:43 PM
akxtreme
Offroad & 4x4
01-30-2006 06:32 PM
ford_wheeler
Offroad & 4x4
02-06-2005 11:27 PM
ford_wheeler
02-06-2005 01:05 AM
Quick Reply: f150 or f250 front hums for a go kart?
