239 Flathead - what 4spd, synched trannys will bolt straight on?? - Ford Truck Enthusiasts Forums
Old 06-10-2012, 12:43 PM
whitley's Avatar
whitley whitley is offline
whitley is starting off with a positive reputation.
I currently have a 239 flathead in my 49' F3. What transmissions will bolt onto it with minimal work? I want to keep the 4 spd on the floor setup, just to have one that is synchronized!
Old 06-10-2012, 02:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Advanced Search is your friend... many threads about the alternatives. If your F-3 has a big "hoop" type crossmember, almost anything will physically fit without cutting, just a matter of connecting it to the bellhousing and fabbing a new trans support.
http://www.ford-trucks.com/forums/11...n-options.html
http://www.ford-trucks.com/forums/11...-progress.html
http://www.ford-trucks.com/forums/11...a-4-speed.html
http://www.ford-trucks.com/forums/10...ailibilty.html
advice on 239 starter Emel 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 04-29-2013 09:10 PM
239 flathead 51 ford f2 (swap?) 3rdshiftDiscretion 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 06-18-2011 06:08 PM
Engine Type lbrauer 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-12-2010 10:46 AM
All this gas mileage talk - what to expect from a 239 Flathead? jgurland 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-03-2006 02:34 PM
Drivetrain upgrade for a 1950 Ford F3 vjp8378 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-19-2005 10:04 PM
Tags
239, decals, engines, flathead, ford, sale, supercharged, truck, vintage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
