Scanguage not connecting - Ford Truck Enthusiasts Forums
Old 06-10-2012, 12:35 PM
dirty1 dirty1 is offline
dirty1 is starting off with a positive reputation.
I bought a Scanguage 2 yesterday. It will not connect to my truck, a 2006 F350. I followed the troubleshooting guide in the manual and it did it did not work. Anyone else have this issue that could help me out prior to calling the company?
Old 06-10-2012, 01:39 PM
Lou Braun Lou Braun is offline
Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.
Check to see if your cigarette lighter works. I believe that the lighter has the same fuse as the OBD2 connector.
Easy fix, I hope.
Lou Braun
Old 06-10-2012, 02:12 PM
RPM371's Avatar
RPM371 RPM371 is offline
RPM371 is gaining momentum as a positive member of FTE.RPM371 is gaining momentum as a positive member of FTE.
There seems to be a fairly high failure rate on them. I had problems getting mine to connect when I bought it. I called Scangauge and they FedEx'd me a replacement. It worked perfect. Their customer service is top notch.
Old 06-10-2012, 02:19 PM
Thanks for the replies. I will check the fuse and see what happens. I that does not work I will be calling them in the morning.
Old 06-10-2012, 07:32 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Make sure the cable clicks all the way in.
Old 06-10-2012, 10:07 PM
elee3's Avatar
elee3 elee3 is online now
elee3 has a great reputation on FTE.elee3 has a great reputation on FTE.elee3 has a great reputation on FTE.elee3 has a great reputation on FTE.
Quote:
I had the same experience. I called them up, they ran me through some troubleshooting steps, then the lady said "I'm sending you a new one". I was impressed with the service.
Old 06-10-2012, 11:15 PM
Eightyfive Flareside Eightyfive Flareside is offline
Eightyfive Flareside is starting off with a positive reputation.
i also had the same issue, mine ended up being a bad plug on the cable. wiggled it around and it worked. I ended up just pushing the wires a lil further into the plug and its been working ever since.
I also have mine with a coupler and a spare cat5e i had laying around attached to it. Seemed to actually help it, hasn't had any issues since i added the cable.
Old 06-11-2012, 08:00 AM
I checked the cable and tried it on the other port. It seems to be working now. Thanks again for all of the help!
Inconsistent boost readings fireman660r 6.0L Power Stroke Diesel 2 02-23-2015 11:24 AM
Can't Find the FICM on My Scanguage II cornstar6207 6.0L Power Stroke Diesel 6 01-12-2015 02:38 PM
scanguage MoHeave 6.0L Power Stroke Diesel 3 03-08-2012 02:31 PM
Scanguage II or Ultraguage? ROBBINthaHOOD 6.0L Power Stroke Diesel 5 09-22-2011 07:10 PM
scanguage II?'s raptor131 6.0L Power Stroke Diesel 5 09-15-2011 07:33 PM
Tags
connecting, edge, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
