My '51 F1 build (Updated Old Skool Hot Rod) - Ford Truck Enthusiasts Forums
Old 06-10-2012, 10:51 AM
Bobby41909 Bobby41909 is offline
Bobby41909 is starting off with a positive reputation.
I've been a member for quite some time doing research for an early F1 build. I finally found one and the restoration is pretty far along. I need a few parts and can't make a post until I have more posts so I thought now would be a good time to start this thread.
I looked at several truck over the past year and found this one within 2 hours of my home. The guy was about 95% complete with the restoration but he was an amatuer and doing a very low budget build. Most everythign I saw was so rusted I thought this was the best one to start with.
I am making an Old school looking hot rod, i.e. flat black paint with a little Von Dutch style accents, red and black interior, and red steel wheels with wide wall tires. However, although it will look old school from the outside I am updating it with a Mustang II suspension, Vintage air, disk brakes, gas tank under the bed....you get the idea.
Here are a few pictures when I found it:
Old 06-10-2012, 10:54 AM
The bed is brand new reproduction and the drive train is a new rebuilt 302 with a C6 trans and a 9" Ford rear. Had disk brake conversion on the straight axle. Truck only had 182 miles on it over a 5 year period he had it. Never cleaned-up the motor and used a bunch of old parts laying around. All set-up wrong which is why he didn't drive it (wrong torq converter, radiator leaked constantly...you get the idea).
Old 06-10-2012, 11:01 AM
Here are some pictures when I brought it home. Looks nice in the pictures but the paint and body work were horrible:
http://i357.photobucket.com/albums/o...Picture001.jpg
Old 06-10-2012, 11:05 AM
OK now she comes a part:
Old 06-10-2012, 11:10 AM
The stripping process begins. Check out the bullet holes!
Old 06-10-2012, 11:14 AM
Body work begins:
Old 06-10-2012, 11:17 AM
The cab gomes back from the blaster....Oh my is that chicken wire?:
Old 06-10-2012, 11:24 AM
The drive train is coming together:
Old 06-10-2012, 11:31 AM
Some new sheet metal and mock-up:
Old 06-10-2012, 11:43 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Wow! You've been busy. Looks great!
Old 06-10-2012, 11:45 AM
A few more:
Old 06-10-2012, 11:48 AM
Currently, she's all mocked up (I'll get updated pictures soon). So she'll come back apart to complete the chassis, POR 15 everything and finalize the body panels for paint. Oh and the cab is currently being worked on (lots of work needed here).
Old 06-10-2012, 11:51 AM
3golfjack's Avatar
3golfjack 3golfjack is offline
3golfjack is gaining momentum as a positive member of FTE.3golfjack is gaining momentum as a positive member of FTE.
Very nice build thread. Great pictures, keep them coming.
Old 06-10-2012, 11:52 AM
One thing we noticed trying to line everything up and make sure all the gaps are perfect; is that an old repair on the passenger side front fender where it meets the lower extension was done wrong. Looked fine when we took it part as we thought the mis-alignment was the worn out suspension at the time. Turns out the guy I bought it from botch-up the metal repair. We fixed the top fender which was pretty easy. The bottom extension section is so far out and with the angles this peice has it'll be cheaper for me to get a good replacement peice than fix this one.
Anyone know where I can get one?
I'd rather not get a fiberglass peice but if I need to I guess I will. You assitance is greatly appreciated
Old 06-10-2012, 11:54 AM
I'd also like to get the deluxe trim and I've seen several versions (I am not an expert) for the hood. I have the single spear and would like to expand that with the upper and lower bars. The hood is so tall I think it looks better with that upgrade.
Anyonw know where I can get a good set? My spears are in great shape so I only need the others with the clips.
Got my new switch box done, what do you all think? TennesseeMustangPerf 1999 to 2016 Super Duty 40 02-18-2017 10:23 AM
1979 Ford F150 4x4 build jmont004 1973 - 1979 F-100 & Larger F-Series Trucks 29 03-19-2010 09:06 AM
My New 7.3! MPG Questions?? mclarengts 1999 - 2003 7.3L Power Stroke Diesel 52 02-03-2010 09:20 PM
A Few of the Many Cars preppypyro Manitoba / Saskatchewan Chapter 31 01-31-2010 10:11 AM
Checking Oil "Short Stick" Method - FYI Bobby Light 6.4L Power Stroke Diesel 14 02-26-2009 09:05 PM
Tags
50s, 51, build, early, f1, ford, lowering, rod, street, truck, updates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
